coolprop plugin problem
coolprop plugin problem - coolprop problem - Messages
#1 Posted: 7/2/2021 10:26:34 AM
Gab
Gab
0 likes in 2 posts.
coolprop_problem
I am using smath version 0.99 build 7822
and coolprop plugin 6.1.7713.14622
and I have the error in the image, you can view it at this address "https://i.postimg.cc/pVKhFJDK/Immagine.png"
how can I solve it?
Thanks in advance.
#2 Posted: 7/3/2021 12:48:45 PM
983 likes in 6866 posts.
That stuff is Viacheslav baby.
WASP from Katmar is not freeware, but works 5 min per session.
For else fluids, I use standard data table.
Doing so, my projects are traceable thus pass QA [Quality Assurance].
#3 Posted: 7/3/2021 2:32:59 PM
Gab
Gab
0 likes in 2 posts.
Sorry but you did not help me very much,
thanks anyway for your time.
#4 Posted: 7/3/2021 8:37:52 PM
CoolProp is supposed to work in Excel, try as offered.
It is such a huge system, unlikely compatible from Smath version to version.
2015, an Smath guru [Anonymous by respect] offered an immense work sheet.
only one did work. The remaining is all red ... [from recollection SS 5346 ?]
#5 Posted: 7/3/2021 9:14:36 PM
From design or else wrongdoing the built-in unit system should
be evaporated to avoid idiotic results.
I Consulted for years with my Ti-58/59 w/o units.
Inst_Viscosity Water.sm (43 KiB) downloaded 53 time(s).
#6 Posted: 7/3/2021 9:29:18 PM
... SS 6179
Page58 CoolProp.sm (22 KiB) downloaded 61 time(s).
#7 Posted: 7/4/2021 6:21:18 AM
1402 likes in 1708 posts.
Authors: Davide Carpi and Mike Kaganski.
Plugin updated, but now the error is different:
#8 Posted: 7/4/2021 3:41:05 PM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
992 likes in 1675 posts.
Hi Viacheslav. After a clean SMath installation, coolprop don't appear as defined function. My windows is 32 bit, do you have where to check that?
Thanks in advance.
#9 Posted: 7/5/2021 1:30:30 AM
It's true, functions are not loaded. I have tested the plugin with local build. Something goes wrong when building on the server. I asked Andrey about it.
Alvaro Diaz Falconi 7/5/2021 4:33:00 AM
#10 Posted: 7/5/2021 11:29:34 AM
Maths CoolProp_Props SpeedSound.sm (28 KiB) downloaded 64 time(s).
#11 Posted: 7/5/2021 6:28:57 PM
554 likes in 1333 posts.
I thought the "not loading" functions are an issue for linux.
And I thought plugin is written maybe only for windows.
So error was general then.
  • New Posts New Posts
  • No New Posts No New Posts
