Solve function problem (simple example)
Solve function problem (simple example) - Messages
#1 Posted: 10/16/2018 5:23:51 AM
Michał Janowski
Michał Janowski
1 likes in 7 posts.
Hello, please tell me what is wrong with this function?
Solve problem.sm (2 KiB) downloaded 66 time(s).
#2 Posted: 10/16/2018 6:38:47 AM
115 likes in 329 posts.
The solution method is numeric and depends on the search limits of the roots. By appropriately setting the limits to the nearest values (Tools->Options->Calculation->Roots (range)-10 + 10), you get the correct result. Downstream of a numerical solution, it is always necessary to proceed to the direct verification of the result (sanity check).
#3 Posted: 10/16/2018 6:43:10 AM
Michał Janowski
Michał Janowski
1 likes in 7 posts.
Full reinstallation (including deletion of plugins) repaired this problem. But what was exact source?.. I don't know.
Edit:
I was writing post when You answered my problem... Change of the range of roots - this is the correct answer.
But now, there is a question: how to use this range? (cuz I remember that I had to increase it becouse there were no roots in my previous calculations and now I need to decrease it).
How to handle with it if it is defined globally for spreadsheet and not for exact calculation?
#4 Posted: 10/16/2018 6:57:11 AM
1417 likes in 2873 posts.
Use solve(4) instead of solve(2). The one with 2 arguments it's handly for calculations on the fly, but not reliable for structured calculations.
#5 Posted: 10/16/2018 7:08:50 AM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
992 likes in 1675 posts.
If you put some big range, you get wrong answers, like in this picture
You can't. Solve with default range for search "all" the roots it's just a helper for some easy calculations. If it give the correct answer, good, but if not, there are not to much to do.
For that you must to use the solve with 4 arguments (or other numerical solver), and get the roots one by one.
#6 Posted: 10/16/2018 7:18:02 AM
Michał Janowski
Michał Janowski
1 likes in 7 posts.
Thank you for your answers! It helped me a lot.
Mroczak
#7 Posted: 10/16/2018 9:41:28 AM
983 likes in 6866 posts.
That will help you more.
Solve roots.sm (25 KiB) downloaded 76 time(s).
  • New Posts New Posts
  • No New Posts No New Posts
