Beta: SMath Studio 0.99.7204 (22 September 2019) - Messages
Changes introduced in current build 0.99.7204
Improvements
- Toolbar items added: Font Name, Bold, Italic, Inderline.
Corrections
- Switching chars from English to Greek and vice versa (Ctrl+g) corrected for MathRegion if Fields and/or unicode chars used inside.
Miscellaneous
- Toolbar items rearranged and behaviors improved;
- Switching chars from English to Greek and vice versa (Ctrl+g) implemented for children Regions;
- Copying Regions contains children Regions using Ctrl+mouse move fixed;
- Rendering of children Regions improved so they better integrated into the container Region content;
- Special characters mode made applicable for children Regions;
- It is now possible to debug and use breakpoints in the children Regions;
- Children Regions stability improved.
Download
SMathStudioDesktop.0_99_7204.Mono.tar.gz (1 MiB) downloaded 757 time(s).
SMathStudioDesktop.0_99_7204.Setup.msi (2 MiB) downloaded 2924 time(s).
Problem for me is I can't change font, bold, italic or underline options.
Toolbar is there but not working. Windows 10 Pro x64 v1903 if it helps.
And a suggestion, the font selection should be with searchable combobox.
*sorry, I had tried to change font outside of the text region. This is not possible for now I guess.
I figured out you had to be inside the text region and select the text to alterate the font, obviously.
(Font doesn't support style regular)
For usability I'd recommend to expose just a small subset of the fonts in the selector (say arial, roman and courier) and leave further options to the context menu or some expert mode.
Also, I recommend to set arial as default font of text widgets (as in Writer plugin).
I guess we will see the option to apply attributes to selected text instead of the whole region soon.
Informationen über das Aufrufen von JIT-Debuggen
anstelle dieses Dialogfelds finden Sie am Ende dieser Meldung.
************** Ausnahmetext **************
System.ArgumentException: Die Schriftart Brush Script MT unterstützt den Schnitt Regular nicht.
bei System.Drawing.Font.CreateNativeFont()
bei System.Drawing.Font.Initialize(FontFamily family, Single emSize, FontStyle style, GraphicsUnit unit, Byte gdiCharSet, Boolean gdiVerticalFont)
bei System.Drawing.Font..ctor(String familyName, Single emSize)
bei SMath.UI.Desktop.MainForm.<>c.(Object , DrawItemEventArgs )
bei System.Windows.Forms.ComboBox.OnDrawItem(DrawItemEventArgs e)
bei System.Windows.Forms.ComboBox.WmReflectDrawItem(Message& m)
bei System.Windows.Forms.ComboBox.WndProc(Message& m)
bei System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Geladene Assemblys **************
mscorlib
Assembly-Version: 4.0.0.0.
Win32-Version: 4.7.2117.0 built by: NET47REL1LAST.
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll.
SMathStudio_Desktop
Assembly-Version: 0.99.7204.3920.
Win32-Version: 1.1.29.0.
CodeBase: file:///C:/FHB/Software/SMath/SMath%2099.7204/SMathStudio_Desktop.exe.
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll.
System
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll.
System.Drawing
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll.
SMath.Manager
Assembly-Version: 0.99.7204.3854.
Win32-Version: 0.99.7204.3854.
CodeBase: file:///C:/FHB/Software/SMath/SMath%2099.7204/SMath.Manager.DLL.
SMath.Environment
CodeBase: file:///C:/FHB/Software/SMath/SMath%2099.7204/SMath.Environment.DLL.
SMath.Drawing
CodeBase: file:///C:/FHB/Software/SMath/SMath%2099.7204/SMath.Drawing.DLL.
System.Configuration
Win32-Version: 4.7.2053.0 built by: NET47REL1.
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll.
System.Core
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll.
System.Xml
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll.
SMath.Controls
CodeBase: file:///C:/FHB/Software/SMath/SMath%2099.7204/SMath.Controls.DLL.
SMath.Math.Symbolic
Assembly-Version: 1.35.7204.3854.
Win32-Version: 1.35.7204.3854.
CodeBase: file:///C:/FHB/Software/SMath/SMath%2099.7204/SMath.Math.Symbolic.DLL.
SMath.Math.Numeric
Assembly-Version: 1.67.7204.3854.
Win32-Version: 1.67.7204.3854.
CodeBase: file:///C:/FHB/Software/SMath/SMath%2099.7204/SMath.Math.Numeric.DLL.
SpecialFunctions
Assembly-Version: 1.12.7204.3854.
Win32-Version: 1.12.7204.3854.
CodeBase: file:///C:/FHB/Software/SMath/SMath%2099.7204/plugins/SpecialFunctions.dll.
HTMLFileType
Assembly-Version: 1.14.7204.3854.
Win32-Version: 1.14.7204.3854.
CodeBase: file:///C:/FHB/Software/SMath/SMath%2099.7204/plugins/HTMLFileType.dll.
ImageFileType
Assembly-Version: 1.11.7204.3854.
Win32-Version: 1.11.7204.3854.
CodeBase: file:///C:/FHB/Software/SMath/SMath%2099.7204/plugins/ImageFileType.dll.
PictureRegion
Assembly-Version: 1.10.7204.3854.
Win32-Version: 1.10.7204.3854.
CodeBase: file:///C:/FHB/Software/SMath/SMath%2099.7204/plugins/PictureRegion.dll.
PlotRegion
CodeBase: file:///C:/FHB/Software/SMath/SMath%2099.7204/plugins/PlotRegion.dll.
SMathFileType
CodeBase: file:///C:/FHB/Software/SMath/SMath%2099.7204/plugins/SMathFileType.dll.
StandardToolboxButtons
Assembly-Version: 1.1.7204.3854.
Win32-Version: 1.1.7204.3854.
CodeBase: file:///C:/FHB/Software/SMath/SMath%2099.7204/plugins/StandardToolboxButtons.dll.
TextRegion
CodeBase: file:///C:/FHB/Software/SMath/SMath%2099.7204/plugins/TextRegion.dll.
ViewerFileType
Assembly-Version: 1.1.7204.3897.
Win32-Version: 1.1.7204.3897.
CodeBase: file:///C:/FHB/Software/SMath/SMath%2099.7204/plugins/ViewerFileType.dll.
XMCDFileType
CodeBase: file:///C:/FHB/Software/SMath/SMath%2099.7204/plugins/XMCDFileType.dll.
SMath.UI
Assembly-Version: 0.99.7204.3897.
Win32-Version: 0.99.7204.3897.
CodeBase: file:///C:/FHB/Software/SMath/SMath%2099.7204/SMath.UI.DLL.
System.Windows.Forms.resources
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.resources/v4.0_4.0.0.0_de_b77a5c561934e089/System.Windows.Forms.resources.dll.
mscorlib.resources
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_de_b77a5c561934e089/mscorlib.resources.dll.
Microsoft.GeneratedCode
Assembly-Version: 1.0.0.0.
System.Drawing.resources
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing.resources/v4.0_4.0.0.0_de_b03f5f7f11d50a3a/System.Drawing.resources.dll.
************** JIT-Debuggen **************
Um das JIT-Debuggen (Just-In-Time) zu aktivieren, muss in der
Konfigurationsdatei der Anwendung oder des Computers
(machine.config) der jitDebugging-Wert im Abschnitt system.windows.forms festgelegt werden.
Die Anwendung muss mit aktiviertem Debuggen kompiliert werden.
Zum Beispiel:
Wenn das JIT-Debuggen aktiviert ist, werden alle nicht behandelten
Ausnahmen an den JIT-Debugger gesendet, der auf dem
Computer registriert ist, und nicht in diesem Dialogfeld behandelt.
WroteProblem for me is I can't change font, bold, italic or underline options.
Please describe when it doesn't work? 1) Create a text region 2) Ensure Region is focused 3) Try to change font settings. Is it working?
WroteAnd a suggestion, the font selection should be with searchable combobox.
It is currently searchable actually. Just press first char of the font name you want while dropdown is opened.
WroteI get a (recoverable) soft crash when browsing fonts with the font selector widget. The preview of some fonts is empty in the dropdown list.
Thank you. Will fix it.
WroteAlso, I recommend to set arial as default font of text widgets (as in Writer plugin).
Yes, will do this. Previously (before TextRegion reviewed) it was not possible.
WroteI guess we will see the option to apply attributes to selected text instead of the whole region soon.
Writer Region is best one for this kind of needs.
I had figured text has to be focused, not region. Edited the previous message near 1 hour ago, sorry.
I have mentioned the searchable combobox as in office word, msword, etc. Not only for the first character of the fonts.
Yes, as for now I agree. But I bet every new user will be frustrated when finding out that text formatting can't be applied just to the selection.
Another (hopefully temporary) workaround is to embed a text region into another text region and to format it separately. However, there are alignment glitches and you can't copy and past such embedded texts:
WroteOh !, the version of Smath Studio 7204 has the same problem
in displaying the description of variables as the version of SS 7200.
Looks like you have saved broken document in 7200. The issue there was that it was not able to load translations for descriptions, so after save it saved everything except those descriptions. Now there are no descriptions, because these entries lost.
WroteYes, as for now I agree. But I bet every new user will be frustrated when finding out that text formatting can't be applied just to the selection.
That image looks same SS 6179 fails to open SS 7109.
Just observed similar incompatibility ... ?
have strictly no interest in the math suite of project(s).
For publishing, SS 6179 is very similar/superior to
OriginLab 7.5... superior to Mathcad 11.
No shame to publish the attached ... organize at will.
Images in Forum aren't 1/1 in file any more [several months].
Just suggestive for interested users.
.WroteWroteOh !, the version of Smath Studio 7204 has the same problem
The file I used did not record it in the SS-7200 version, and it was the one I used to test the SS-7202 version, which worked perfectly.
I did another test on SS-7204 with files that I didn't open in any of the mentioned versions, and the function of displaying the variable description fails.
Carlos
Here is the same file running on a portable version of SS-7202,
which shows that the description of variables appears complete.
The same file running in the SS-7204 version, which shows that the description of variables does not appear complete.
Carlos
WroteThe same file running in the SS-7204 version, which shows that the description of variables does not appear complete.
I cannot reproduce this issue. Please could you send a file in question to me by e-mail?
Thanks in advance!
Here is a sheet of the file that shows the behavior that indicates
in the post with the versions of SS-7202 and SS-7204.
Test_SS7202_SS7204.sm (48 KiB) downloaded 62 time(s).
I hope it helps to find the problem.
Thank you
Carlos
WroteHere is a sheet of the file that shows the behavior that indicates
Thank you! Reproduced now.
Will fix soon.
Regards.
Also any text that was 8 font as soon as I move it or copy it, it changes to size 10.
WroteI can't change the default font size. Currently it is set at 10. If I try to change it in the "ribbon", it just switches back to 10 instantly. If I try to via tools-> options, it will change for one text region, but as soon as I finish it changes back to 10.
I confirm this fact.
Unfortunately, the font size cannot be changed and is always set to '10'
Best regards,
Andrei
New Posts
No New Posts
