Beta: SMath Studio 0.99.7792 (02 May 2021)
Beta: SMath Studio 0.99.7792 (02 May 2021) - Messages
#1 Posted: 5/2/2021 10:46:08 AM
2270 likes in 3734 posts.
Changes introduced in current build 0.99.7792
Improvements
  • Multiple improvements performed in Search functionality (better support in MathRegion; critical issues fixed; better support for search in Descriptions and Area/Separator; automatic scrolling in Document mode);
  • Cursor movement corrected while the mouse pointer is between the pages in Worksheet mode.
Corrections
  • Scrolling to cursor improved in Worksheet mode;
  • Several text encoding related issues in MathRegion fixed;
  • Worksheet/Document autoscrolling enabled during work with selection inside a Region;
  • Minor improvements performed for scrolling;
  • Switching to Header/Footer by doubleclick fixed for the Worksheets contains Separator Region and background set;
  • Text encoding related issue fixed in Plot Region.
Miscellaneous
  • Refactoring.
Download
SMathStudioDesktop.0_99_7792.Mono.tar.gz (1 MiB) downloaded 724 time(s).
SMathStudioDesktop.0_99_7792.Setup.msi (2 MiB) downloaded 2524 time(s).
sergio 5/2/2021 12:22:00 PM, NDTM Amarasekera 5/2/2021 1:57:00 PM, Serg 5/7/2021 11:12:00 AM
#2 Posted: 5/2/2021 1:18:24 PM
João Felipe Seráfico Melo
7 likes in 62 posts.
Hi, Andrey!
I'm facing problems for selecting and moving objects with this update.
#3 Posted: 5/2/2021 1:55:01 PM
NDTM Amarasekera
NDTM Amarasekera
130 likes in 352 posts.
Hi Andrey!
Problems with Formatted Label.
Apparently, it occurs when both text and background color is specified with "light ..." as shown.
Andrey Ivashov 5/2/2021 2:28:00 PM
#4 Posted: 5/2/2021 2:10:11 PM
554 likes in 1333 posts.
Hi, Andrey!
Me too, there is a performance drop with moving or scrolling regions.
#5 Posted: 5/2/2021 2:24:08 PM
Hi, Andrey!
How can I reproduce it?
#6 Posted: 5/2/2021 2:28:52 PM
Hi Andrey!
To overcome this issue you need to remove spaces from color name (" "). I will fix this.
Thank you!
Davide Carpi 5/2/2021 2:42:00 PM
#7 Posted: 5/2/2021 2:44:56 PM
1417 likes in 2873 posts.
Hi Andrey!
Thank you!
In the meantime I've added a workaround in the plugin.
#8 Posted: 5/2/2021 3:01:28 PM
Cleaning "~/.config/SMath" directory and reinstalling all plugins solved the performance issue.
Possibly would be resulted same with cleaning the "Roaming/SMath" directory under Windows.
Andrey Ivashov 5/2/2021 6:14:00 PM, NDTM Amarasekera 5/2/2021 11:49:00 PM
#9 Posted: 5/2/2021 6:11:30 PM
Hi Andrey!
Thank you!
This workaround will not work.
You need to change line
SMath.Drawing.Graphics.GetColorByName(color.Replace(" ","");
with
SMath.Drawing.Graphics.GetColorByName(TermsConverter.DecodeText(color));
This is because variable color contains value from Term where text is always encoded. While GetColorByName does not except encoded values.
In case you want to see an example: I did the same correction in the Plot Region plug-in in my latest commit in main repo.
#10 Posted: 5/3/2021 12:19:42 AM
NDTM Amarasekera
NDTM Amarasekera
Originally Posted by: joaobr [url=/forum/yaf_postsm70583_Beta--SMath-Studio-0-99-7792--02-May-2021.aspx#post70583][/url]Hi, Andrey!
I too had this problem.
Even after a clean re-installation, the problem still exists.
#11 Posted: 5/4/2021 7:32:14 AM
Please describe in details what are you experiencing.
#12 Posted: 5/4/2021 10:11:35 AM
Sorry about the late reply.
When I open a selection box by holding the left click, it gets stucked, so I can't select objects and move them around.
I can select objects by clicking but can't drag them.
I'm testing right now and it happens only in worsheets created in previous versions.
#13 Posted: 5/4/2021 1:46:26 PM
churichuro
churichuro
28 likes in 79 posts.
trouble moving
Andrey Ivashov 5/6/2021 6:01:00 PM
#14 Posted: 5/4/2021 10:47:48 PM
NDTM Amarasekera
NDTM Amarasekera
Problem is as shown in post #13.
It occurs for files created in latest SS also.
Sorry for the delay.
#15 Posted: 5/5/2021 12:30:37 PM
NDTM Amarasekera
NDTM Amarasekera
Did another clean-reinstallation.
Now the problem is solved only for new files saved in 99.7792.
But not for previous versions.
Thank you.
#16 Posted: 5/5/2021 1:08:40 PM
983 likes in 6866 posts.
Do you mean for documents created in previous versions ?
As far back to previous versions ?
As well I noticed that last version affects "0.98.6179.21440"
Roots (range) options => Can't be set anymore ± 2.5
... Takes integers only or set it back to integer.
That happened from downloading some Forum latest version
even if denied updating like usual !
Take care ... Jean
#17 Posted: 5/5/2021 2:24:38 PM
NDTM Amarasekera
NDTM Amarasekera
Yes. The last one before 99.7792.
Previous versions also. Can't remember the version number but the dates are given below.
29/05/2014
19/05/2016
27/08/2016
21/06/2018
23/09/2.18
26/06/2019
23/01/2020
Thanks.
Take care.
#18 Posted: 5/6/2021 5:25:46 AM
Martin_B
Martin_B
21 likes in 84 posts.
Can't remember the version number ...
If you open the SMath file with a text editor, the second line shows the version:
e. g.
#19 Posted: 5/6/2021 8:54:51 AM
NDTM Amarasekera
NDTM Amarasekera
e. g.
Thank you.
#20 Posted: 5/6/2021 9:32:04 AM
if you can run the worksheet, just use appVersion(-digits), the negative values are for the worksheet version while the positive are for the executable.
  • New Posts New Posts
  • No New Posts No New Posts
