modifying tables
modifying tables - Messages
#1 Posted: 4/23/2019 4:14:53 PM
The Cross
The Cross
0 likes in 73 posts.
I just inserted a table region into my sheet, but I can't figure out how to change the number of rows or columns, or how to type in it. I select the boxes and a popup that I don't know what to do with pops up.
#2 Posted: 4/23/2019 6:36:03 PM
983 likes in 6866 posts.
Table Region Carlos.sm (12 KiB) downloaded 91 time(s).
#3 Posted: 4/23/2019 7:14:04 PM
The Cross
The Cross
I typed exactly what is in the Table Region Carlos.sm and then added the table below with the Insert Table command, and still it does not work.
Don't know why the picture of the smath file is so big.
#4 Posted: 4/23/2019 10:58:10 PM
Once you have inserted the Table from the insert menu,
in that 3 x 3 chess board: type Table in the place holder.
Print Screen, paste in Paint, Select, paste in a tool
that will save as *.PNG [I use WinGrab for over 20 years]
#5 Posted: 4/24/2019 10:04:34 AM
The Cross
The Cross
I defined the temp in degrees F, but it put it in degrees K
#6 Posted: 4/24/2019 12:40:21 PM
The Cross
The Cross
What I want to do is produce a table similar to the image I attached: DFU TABLE.png Also, What does the first definition do for the table? In the example it says
Time:= 5 day
Flow := 0.005 ft3/min
Temp := 20F
#7 Posted: 4/24/2019 12:55:59 PM
Smath is an advanced CAS. Maybe purchase a tool to list the barn population.
What about Excel, Word ... ?
WinGrab is freeware perpetual for all Windows versions
In 3 clicks for decent image in the Forum:
attach in the Forum
#8 Posted: 4/24/2019 4:57:57 PM
CBG
CBG
77 likes in 312 posts.
Hello
This is a part of your table
Table Region Carlos_R1.sm (28 KiB) downloaded 70 time(s).
Carlos
#9 Posted: 5/10/2019 10:14:44 AM
The Cross
The Cross
After you produce the table in SMath, are the numbers in the table usable in a calculation? If not, then there is no point, and it is better to just copy and paste from Excel.
#10 Posted: 5/10/2019 10:36:58 AM
Obviously, you can use any element from Smath data Table or from matrix result,
just address the element as needed ... no limit.
#11 Posted: 5/10/2019 2:01:55 PM
... address new value by element
You can add/delete cols/rows, value the cols/rows added.
#12 Posted: 5/10/2019 7:05:03 PM
CBG
CBG
Of course, look at the operation fixture 1.2 by fixture 1.4, which results in 4. within the same table.
Carlos
#13 Posted: 5/14/2019 3:43:20 PM
The Cross
The Cross
#14 Posted: 5/14/2019 4:32:46 PM
Why does my table say 1 deg F and not 30 ?
Please: attach the document so helpers won't have to redo.
#15 Posted: 5/14/2019 4:37:21 PM
The Cross
The Cross
test.sm (18 KiB) downloaded 50 time(s).
#16 Posted: 5/14/2019 4:38:41 PM
1417 likes in 2873 posts.
Seems to me that simply you are not using the Temp variable in your Table matrix.
#17 Posted: 5/14/2019 4:44:24 PM
The Cross
The Cross
then, it goes completely crazy and puts in an arbitrary value of 137.79
test.sm (18 KiB) downloaded 51 time(s).
#18 Posted: 5/14/2019 4:52:24 PM
CBG
CBG
Here is the correction. It was still necessary to define your own unit of
degrees farenheit to prevent Smath Studio from interpreting it as Kelvin degrees.
On the other hand in the table was missing include the variable Temperature
(temp) divided by the units (° F)
test _Britt1.sm (19 KiB) downloaded 57 time(s).
Carlos
Davide Carpi 5/14/2019 4:59:00 PM
#19 Posted: 5/14/2019 4:57:31 PM
I'd like it was completely arbitrary, I would have created some sort of artificial intelligence
Jokes aside, it is probably the value in the base unit (Kelvin).
I'm sorry but I'm from mobile right now, I can't check it deeply nor provide some example, I hope some of our skilled users can help you more here.
Edit: thank you Carlos
#20 Posted: 5/15/2019 11:09:11 AM
The Cross
The Cross
Can you make a table in one SMath file, and have a calculation in another SMath file refer to the table in a calculation?
  • New Posts New Posts
  • No New Posts No New Posts
