Conditionally Formatted Labels
Conditionally Formatted Labels - Add Conditionally Formatted Labels in SMath Studio worksheets - Messages
#81 Posted: 1/17/2023 9:19:38 AM
German
German
0 likes in 8 posts.
Here it is.
losa-forum.sm (862 KiB) downloaded 64 time(s).
Sorry Jean but i don't understand what i'm supposed to see. I also get "data - not defined".
#82 Posted: 1/17/2023 10:18:15 AM
983 likes in 6866 posts.
Sorry Jean but I don't understand what I'm supposed to see. I also get "data - not defined".
data not defined probably indicates some plugins not installed.
Maybe other problems wrt your version.
#83 Posted: 1/17/2023 10:55:42 AM
Here it is.
Document does not open ... incorrect format
#84 Posted: 1/17/2023 11:15:28 AM
German
German
0 likes in 8 posts.
SMath Studio Desktop 64-bit
Version: 1.0(build: 8348)
Date: 9/11/2022
ConditionallyFormattedLabel: 1.0.8138.35454
#85 Posted: 1/17/2023 11:20:05 AM
1417 likes in 2873 posts.
If you hover over the asd definition you can see that there is an unsolved "d" dependancy that triggers the error.
The same happens if you try to force a numerical evaluation using eval()
#86 Posted: 1/17/2023 12:05:21 PM
German
German
0 likes in 8 posts.
That is it!
As allways thanks!!
But still don't understand why Jean files fails.
#87 Posted: 1/17/2023 12:12:05 PM
Date: 9/11/2022
Slide left the Formatted Label
Side right the graph, remove the Σ no definido
You should see the plot.
#88 Posted: 1/17/2023 12:15:52 PM
That is it!
As allways thanks!!
You're welcome!
There is an excel data import at the begin of the file, is not related to the issue however so it doesn't matter. nevermind I was looking at your file.
If you remove the 3 inline evaluations it will work.
2023-01-17 16_28_05-SMath Solver - [Image Formated LABEL [Oxyhemoglobin] FORUM.sm].png
#89 Posted: 1/17/2023 12:39:57 PM
German
German
0 likes in 8 posts.
My file can be an example of things NOT to do.
#90 Posted: 10/14/2023 11:08:58 PM
Rogalski
Rogalski
0 likes in 7 posts.
Can we manage the units that are displayed?
I have a load in kN/m2 and the result appears as kg/(m*s2).
The idea is to present only positive values (with the appropriate unit).
kind regards
Conditionally Formatted Labels_unity.sm (5 KiB) downloaded 69 time(s).
#91 Posted: 10/14/2023 11:52:58 PM
The easier way might be something like this
2023-10-14 18_53_23-SMath Solver - [Conditionally Formatted Labels_unity.sm_].png
press2text(x):line(concat(var2str(x/'kPa,1),"\0020\kN\002F\m\00B2\",1,1)
Oscar Campo 10/15/2023 12:41:00 AM
#92 Posted: 10/15/2023 12:08:06 AM
Rogalski
Rogalski
0 likes in 7 posts.
Thank you very much.
This is exactly what I needed.
#93 Posted: 10/15/2023 11:51:23 PM
Rogalski
Rogalski
0 likes in 7 posts.
I'm looking for a way to represent the letter D as a subscript. Unfortunately, Unicode doesn't seem to provide this option...
Is there any possibility to parameterize individual characters that will be presented?
#94 Posted: 10/16/2023 3:06:16 AM
You can subscribe whatever.
mysystem dot HelloGrandMa
#95 Posted: 10/17/2023 1:32:30 AM
Rogalski
Rogalski
0 likes in 7 posts.
thanks for the information, but I'm not sure if I expressed myself correctly. I mean the subscripts in the "phrases" that I marked in the drawing.
Davide sent the function shown above in which I need to use subscripts.
#96 Posted: 10/17/2023 2:13:46 AM
Oscar Campo
Oscar Campo
124 likes in 298 posts.
Davide used superscript unicode character for write: "kN\002F\m\00B2\" wich renders as "kN/m²" so, you can use unicode characters...but not all characters have subscript version.
Please check here: https://www.compart.com/en/unicode/search?q=subscript#characters
Oscar
#97 Posted: 10/17/2023 1:30:37 PM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
992 likes in 1674 posts.
Hi Karol. This could be a workaround, using the SMath Plot region.
label.sm (6 KiB) downloaded 61 time(s).
Oscar Campo 10/17/2023 4:52:00 PM
#98 Posted: 10/17/2023 6:15:56 PM
Subscripts in native Solver 30405.
Collect as many the project needs,
call the wanted by indexing.
Maths Subscript.sm (10 KiB) downloaded 66 time(s).
#99 Posted: 10/17/2023 11:23:29 PM
Rogalski
Rogalski
0 likes in 7 posts.
Wow great Alvaro. Thank you very much.
I'm impressed.
#100 Posted: 10/17/2023 11:26:39 PM
Rogalski
Rogalski
0 likes in 7 posts.
Jean Giraud,
Thank you too.
But I have to put in some effort to understand what you sent.
Kind regards
  • New Posts New Posts
  • No New Posts No New Posts
