Function from plot
Function from plot - Messages
#1 Posted: 6/6/2023 8:19:33 AM
Valery Ochkov
Valery Ochkov
55 likes in 633 posts.
How can I get a function from this plot?
#2 Posted: 6/6/2023 8:59:59 AM
983 likes in 6866 posts.
How can I get a function from this plot ?
1. Probably from the expensive digitizer suggested by Richard [Mathsoft Collaboratory]
2. Piecewise from Tracer.
3. Try Mathsoft digitizer.
4. Smath difficult
At this point from the collected data set, fit a model function.
Valery Ochkov 6/6/2023 10:24:00 AM
#3 Posted: 6/6/2023 10:05:20 AM
Brian Runagle
Brian Runagle
13 likes in 27 posts.
Does this help?
Graphing.pdf (164 KiB) downloaded 67 time(s).
Brian
#4 Posted: 6/6/2023 10:15:02 AM
⚜ Kenny Lemens, P.E. ᵂᴵ
74 likes in 164 posts.
Greetings,
How can I get a function from this plot? 🖼
That is a straight line on a semi-log graph; you can reference this handout: https://inside.mines.edu/~epoeter/_GW/LAB/EquationsOfStraightLinesOnDifferentTypesGraphPaper.pdf
Per this handout, your equation should be
y = b + m*log(x)
where:
  • m = difference in y over one log cycle of x
  • b = y value corresponding to x=1
May this be of Good Help;
#5 Posted: 6/6/2023 12:44:34 PM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
992 likes in 1675 posts.
Hi. You can try this post Approximation of a functional curve in a digital image or this other one: Embedding images into a plot
Вячеслав Мезенцев 6/6/2023 2:16:00 PM, Valery Ochkov 6/6/2023 1:45:00 PM
#6 Posted: 6/6/2023 2:19:52 PM
Hello Valery,
some Smath digitizing utilities
Cheers, Jean.
Digitize Tracer 15.sm (28 KiB) downloaded 49 time(s).
Digitize OVNI Copy.sm (69 KiB) downloaded 43 time(s).
Digitize Contour Isocurve Himmelblau Copy.sm (106 KiB) downloaded 44 time(s).
Digitize Curve.sm (295 KiB) downloaded 49 time(s).
Digitize Contour.sm (829 KiB) downloaded 45 time(s).
Digitize Clean_Strip_Smooth.sm (1 MiB) downloaded 47 time(s).
#7 Posted: 6/6/2023 3:29:30 PM
... this Himmelblau has resident Gray matrix.
Digitize Contour Isocurve Himmelblau Copy.sm (107 KiB) downloaded 47 time(s).
Valery Ochkov 6/7/2023 1:02:00 AM
#8 Posted: 6/6/2023 5:11:16 PM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi. Hope this helps.
Modeling a functional curve in a digital image.pdf (860 KiB) downloaded 65 time(s).
Modeling a functional curve in a digital image.sm (1 MiB) downloaded 64 time(s).
Valery Ochkov 6/7/2023 1:02:00 AM, sergio 6/7/2023 6:34:00 AM, darlbeck 6/7/2023 2:59:00 PM
  • New Posts New Posts
  • No New Posts No New Posts
