Limits of functions of 2 variables
Limits of functions of 2 variables - Messages
#1 Posted: 2/21/2017 5:58:54 PM
frapuano
frapuano
13 likes in 115 posts.
Hi Martin,
this is just to know if it is possible from Smath using Maxima to handle limits of functions of 2 variables.
Thanks in advance for your feedback
Franco
#2 Posted: 2/21/2017 6:39:02 PM
1222 likes in 2150 posts.
There is no hint on such capabilities in the maxima handbook.
#3 Posted: 2/22/2017 1:11:28 PM
983 likes in 6866 posts.
The limit of a function of two variables is the contour limit @ user value.
Maxima X_Y plots by default the 0 level contour. For other 'level(s)'
use the maple solve block.
#4 Posted: 2/22/2017 2:08:40 PM
What is a Maxima X_Y plot? Why would you need some solver for other levels if you can plot 0 level?
As I understand, the bivariate limit is a function of the x,y values and of the direction of approach.
It would be helpful to see what you expect to see (examples).
#5 Posted: 2/23/2017 1:41:09 PM
What is the meaning of: handle limits of functions of 2 variables
Wait for the f(x,y):=
X_Y plots contour of any level in the domain of existence w/o solver.
The solver is for discretising the export.
Contour [Wolfram Looping].sm (19 KiB) downloaded 71 time(s).
#6 Posted: 2/24/2017 5:15:10 AM
frapuano
frapuano
Joan unlukily doesn't work this way.
For a limit of a function in 2 variables ( or more ) its results may depends on the path used to reach it so the program I guess that needs to use a coordinate conversion or other methods to find it and to check that is independent from the path used .
So it is necessary a specific algorithmic "intelligence" to solve such a type of problems.
In my search have found a Wolfram alpha widget that does this in a very good way ...
http://www.wolframalpha.com/widgets/view.jsp?id=2958433016861a528d6221f5ac88eefd
Franco
#7 Posted: 2/24/2017 3:11:27 PM
Wolfram is of no help as you can check by yourself: it is ill posed.
"the limit of functions of two variables ..."
read: implict f(x,y) have solutions wrt 'x' or 'y' alternately.
Read the two Smath documents
Forum Implicit Limit.sm (12 KiB) downloaded 64 time(s).
Forum Implicit Wolfram.sm (4 KiB) downloaded 61 time(s).
#8 Posted: 2/24/2017 3:26:01 PM
From the previous work sheets, answer is probably "NO"
Maxima will plot many implicit functions.
In the attached:
1. Valery Ochov "ImplicitFunctionGrapher"
2. an example of the CONTOUR matrix extractor
I presume I can exemplify the 'maple' RootOf,
Please, let me know.
Contour ImplicitFunctionGrapher.sm (28 KiB) downloaded 70 time(s).
Contour Advisor [Publish].sm (26 KiB) downloaded 64 time(s).
  • New Posts New Posts
  • No New Posts No New Posts
