Advantage of vectorize function
Advantage of vectorize function - Data Analysis Using Truth Tables - Messages
#1 Posted: 7/6/2019 2:51:39 AM
NDTM Amarasekera
NDTM Amarasekera
130 likes in 352 posts.
On the request of a fellow Engineer, the attached SM program was developed
to find the Standardized Precipitation Index (SPI).
58 years of daily precipitation data was available.
The SPI is widely used to analyze meteorological drought on a range of
time scales. There are proprietary software packages for this purpose.
The “vectorize” function was pretty handy and fast in analyzing various conditions.
SPI_cal-Rev & Improved-Final.sm (1 MiB) downloaded 162 time(s).
Rainfal_Data.xlsx (486 KiB) downloaded 117 time(s).
Radovan Omorjan 7/6/2019 4:23:00 AM, frapuano 7/6/2019 5:13:00 AM, Davide Carpi 7/6/2019 11:20:00 AM
#2 Posted: 9/19/2019 12:23:07 PM
NDTM Amarasekera
NDTM Amarasekera
Attached file may be useful in handling data, where it may be
necessary to extract numerical values removing any strings, or
negative values, zeros etc.
Data Analysis Using Truth Table.sm (78 KiB) downloaded 92 time(s).
#3 Posted: 9/19/2019 12:44:46 PM
983 likes in 6866 posts.
Maybe more or otherwise in there.
Utilities Matrix Truth Table.sm (59 KiB) downloaded 99 time(s).
Utilities Matrix Truth Table [UNSORTED alyles].sm (15 KiB) downloaded 90 time(s).
Utilities Matrix Truth Table [Locate row_col].sm (43 KiB) downloaded 95 time(s).
#4 Posted: 4/13/2020 1:20:47 PM
NDTM Amarasekera
NDTM Amarasekera
Advantage of vectorize function revisited.
Another practical example attached, with extensive use of the vectorize function. No loops used.
Comments by Martin, Jean, Razonar and others on this subject much appreciated.
Hope this may be useful for beginners.
Cheers
SPI_cal-Millawana_Multiple_R5.sm (178 KiB) downloaded 91 time(s).
rainfall_KalaOyaBAsin.xlsx (585 KiB) downloaded 66 time(s).
#5 Posted: 4/13/2020 1:47:05 PM
Sorry mon Ami ... SS 6179 does not open ... Jean
#6 Posted: 4/13/2020 2:04:20 PM
NDTM Amarasekera
NDTM Amarasekera
Sorry. PDF attached.
SPI_cal-Millawana_Multiple_R5.pdf (1 MiB) downloaded 109 time(s).
Davide Carpi 4/14/2020 9:24:00 AM, frapuano 4/14/2020 11:57:00 AM
#7 Posted: 4/14/2020 9:04:19 AM
Thanks for the *.PDF ... superb quality !
#8 Posted: 11/12/2020 3:56:59 AM
NDTM Amarasekera
NDTM Amarasekera
I have found this useful in day to day work.
Data imported from MS Excel sheet, and using "findrows" function to sum daily data to monthly totals.
sergio 11/12/2020 5:23:00 AM
#9 Posted: 11/16/2020 2:13:48 PM
NDTM Amarasekera
NDTM Amarasekera
Attached is a simplified version of a project work for demonstration only.
The data file consists of date strings, and hence, had to be transformed into numeric.
Hope this may be useful for beginners. Vectorize function very useful in this exercise.
Handling DATE STRINGS.sm (16 KiB) downloaded 73 time(s).
sergio 11/17/2020 2:39:00 PM
#10 Posted: 11/16/2020 8:48:19 PM
The secret is inside your nice piece of work ... superb, thanks.
Take care my Friend ... Jean
#11 Posted: 11/16/2020 11:58:06 PM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
992 likes in 1675 posts.
Hi. Handling data strings you have also this cheat for convert dates to numeric matrices.
Handling DATE STRINGS.sm (20 KiB) downloaded 72 time(s).
sergio 11/17/2020 2:39:00 PM, NDTM Amarasekera 11/17/2020 10:29:00 PM
#12 Posted: 11/17/2020 1:41:25 AM
NDTM Amarasekera
NDTM Amarasekera
Thank you Jean for your kind words and encouragements. Take care.
Thank you Razonar for the superb alternative. Take care.
#13 Posted: 11/17/2020 9:44:04 AM
You too Alvaro: take care, thanks ... Jean
#14 Posted: 2/2/2021 4:35:43 AM
NDTM Amarasekera
NDTM Amarasekera
Revised program to handle date strings.
Handling DATE STRINGS+Alvaro.sm (43 KiB) downloaded 61 time(s).
Alvaro Diaz Falconi 2/2/2021 3:35:00 PM
#15 Posted: 2/2/2021 11:27:50 AM
Thanks Collab for that most useful work.
Saved ... for future use.
#16 Posted: 2/2/2021 3:44:06 PM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi Amarasekera. Yes, that one, thanks. The fact you're showing despite to me about the speed in procedures with arrays. In the attached some comments about the need to redefining M:=M where M is a matrix argument in a procedure.
EvalTest.sm (17 KiB) downloaded 67 time(s).
EvalTest.pdf (73 KiB) downloaded 53 time(s).
sergio 2/3/2021 6:33:00 AM
#17 Posted: 2/2/2021 6:53:27 PM
Your last Speedy Gonzalez is the Smath Numerical Fairy.
As it looks, pure numerical code coincidence as a fact.
Slightly adapted for convenience SS 6179
Thanks, cheers ... Jean
Maths eval(,) TEST.sm (16 KiB) downloaded 65 time(s).
#18 Posted: 2/2/2021 7:26:52 PM
Ruben Sidranski
Ruben Sidranski
17 likes in 463 posts.
Alvaro,
Are you showing that by redefining Mo variable, within the program, it speeds it up 30 fold? That makes no sense
The only thing that remotely comes to mind is that M, being defined within the program structure as M:=Mo, is not having to read for the variable from the outside.
Have you, or anyone else, tried this on other programs?
#19 Posted: 2/2/2021 7:54:30 PM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Alvaro,
Yes. Please, try to check in your environment if this is true also. (Notice that my laptop is very slow, because always is running something else or overloaded by some other procedures)
Yes. For this was the issue in the original Amarasekera work, and why I say that he was the first showing this behavior. But I have other codes where using M:=M speed up slow procedures. Actually anything with a loop over a matrix.
Here intermediate timing result, which I can't explain
#20 Posted: 2/2/2021 10:13:47 PM
What's wrong or incorrect in there is length it shouldn't exist in Smath
  • New Posts New Posts
  • No New Posts No New Posts
