DISLIN - A high-level plotting library for displaying data - Messages
#41 Posted: 4/4/2016 3:30:31 PM
WroteJean, on a side note, what is your comment on a quality of DISLIN generated plots?
There are already so many 3D plots, many are freeware.
Scilab, DISLIN ... Surfer 8 [dedicated Contour plot, not freeware].
I see DISLIN via a menu driven and equation editor, Mathcad style.
The first thing is a the same CreateMesh than Mathcad. Let say the
two planes X, Y and the level Z plane and in parametric style.
That sets the complete 3 D system, meshed at will and supporting
the entire user rotation from command line as well as cylindrical/
spherical plots and export the corresponding matrices. Contour is
something else of much different nature. Contour plots ends being
an XY plot. I have a Mathcad contour program [done by Collab].
Just scared to attempt Coding in Smath. Some of you gurus, I can
make an image of the program for your bed time reading.
There remains the question about freeware: how far can somebody
reverse Engineer and redistribute ?
Cheers Alex, Jean
#42 Posted: 4/4/2016 6:54:22 PM
... that's what I meant about a comprehensive "DISLIN start".
Contour is for exporting specific contour data. The feed is a
matrix, either well populated or splined and you get what you
want. Collapse the function, plug the matrix from source or
from function ... ready for the contour(s), just few clicks.
I lost patience trying to imitate Mathcad "on error".
So, attempting the program is not tempting.
The program images included in the *.sm work sheet.
Contour Electron.sm (239 KiB) downloaded 110 time(s).
Alexander O. Melnik 4/4/2016 7:01:00 PM
#43 Posted: 10/27/2020 8:50:31 AM
Hello.
Currently I'm working to improve SMath Studio start up time. Have good results (made it up to 4x faster), but I've found that DISLIN plug-in requires from 4 to 14 seconds (different environment) to response on call to GetTermsHandled. Which is the most significant part of SMath Studio start up time.
Is it possible to improve the logic here?
#44 Posted: 10/27/2020 9:02:58 AM
I'll see what I can do or will change the way I use it.
Andrey Ivashov 10/27/2020 9:22:00 AM, Davide Carpi 10/27/2020 11:02:00 AM, sergio 10/27/2020 11:51:00 AM
#46 Posted: 11/4/2020 11:36:55 PM
#47 Posted: 11/5/2020 12:34:36 PM
Updated.
Changes:
- updated to DISLIN 11.3.3 (799 functions);
- refactored.
QuoteGrant of Free Usage
You are allowed to use DISLIN for free. Either as a private person or in a
commercial or non-commercial environment. There are no limitations.
DISLIN. Example 1.sm (95 KiB) downloaded 209 time(s).
DISLIN. Example 1.pdf (287 KiB) downloaded 233 time(s).
#48 Posted: 6/1/2022 2:30:37 PM
4 users liked this post
sergio 6/1/2022 4:46:00 PM, João Felipe Seráfico Melo 6/1/2022 9:58:00 PM, NDTM Amarasekera 6/1/2022 10:30:00 PM, Mark R Harris 6/2/2022 3:36:00 AM
#49 Posted: 1/29/2025 1:32:17 AM
Plugin updated:
- Text descriptions added to the functions implemented in the plugin (>90% descriptions found).
Вячеслав Мезенцев 1/29/2025 2:03:00 AM, Oscar Campo 1/29/2025 2:33:00 AM, NDTM Amarasekera 1/30/2025 10:41:00 AM
#50 Posted: 1/29/2025 10:19:59 PM
Here you need to keep in mind that the source file with a list of functions is automatically formed using the template distinct.tt. Therefore, it is advisable to come up with a way of automatically adding a description to each function.
New Posts
No New Posts
