1 Pages (11 items)
Length of a Matrix - Messages
#1 Posted: 2/27/2019 8:41:15 PM
Hi. Is this the expected behavior?
Append.sm (6 KiB) downloaded 68 time(s).
I hope not. I expect A' = [1 2 3 4]
#2 Posted: 2/27/2019 9:32:07 PM
#3 Posted: 2/27/2019 9:53:45 PM
#4 Posted: 2/27/2019 10:20:41 PM
#5 Posted: 2/27/2019 10:25:09 PM
OK, you are imitating MCD.
I'm trying to imitate Wolfram's Mathematica Append.
#6 Posted: 2/28/2019 1:59:51 AM
WroteI'm trying to imitate Wolfram's Mathematica Append.
Not that much miraculous Mathematica 4.0
Mathcad APENDPRN was almost never used.
Useful to compact/file a data set with wisely
collected the fitting coefficients.
On that application, Smath is far superior ... Explain
Smath can save same stuff + the formula ... WOW !
Saludad Alvaro [is that correct ?]
Page24 Alvaro.sm (15 KiB) downloaded 62 time(s).
#7 Posted: 2/28/2019 5:48:34 AM
Yes it is correct, or at least it conforms with the general approach of the program (vectors are single column matrices, anything else is a matrix). You might see it better in a 2 rows matrix:
The new indices are added expanding the matrix vertically; there is no special case for single-row matrices.
For your task, one way could be this:
Or this:
Or this:
frapuano 2/28/2019 6:06:00 AM, Alvaro Diaz Falconi 2/28/2019 6:07:00 AM, NDTM Amarasekera 2/28/2019 12:13:00 PM
#8 Posted: 2/28/2019 1:22:34 PM
#9 Posted: 2/28/2019 2:42:13 PM
#10 Posted: 2/28/2019 3:05:51 PM
Close. Correct it's Saludos Jean.
WroteYes it is correct, or at least it conforms with the general approach of the program (vectors are single column matrices, anything else is a matrix). You might see it better in a 2 rows matrix:
Thanks for the explain. You give to me the rule for understand the result. Just as comment, matlab don't follow that, and gives this results:
#11 Posted: 3/1/2019 1:03:18 AM
WroteJust as comment, matlab don't follow that, and gives this results:
What Matlab does Smath does as well with lot more user specifics.
Matlab => MDA [Muliti Dimensional Array]
Mathematica => Cell Array
They just have their system. I can do whatever from this example
and very quick too, just few more modules.
1 Pages (11 items)
New Posts
No New Posts
