Beta: SMath Studio 0.99.7542 (25 August 2020)
Beta: SMath Studio 0.99.7542 (25 August 2020) - Messages
#1 Posted: 8/24/2020 8:24:09 PM
2270 likes in 3734 posts.
Changes introduced in current build 0.99.7542
Improvements
  • COUNT and PAGENUM fields improved to allow setting up an offset for the output number;
  • Alignment context menu item added to TextRegion;
  • TextRegion improved to support changing Line spacing using context menu.
Corrections
  • trunc() function does not accept units in the argument anymore;
  • Empty Heder/Footer supported now;
  • Basic behaviors of the TextRegion improved (text selections);
  • SS-4612 Line wrapping significantly improved in TextRegion;
  • Fixed "There is no xml start tag" issue happens when self-closed tag of the Region was included into *.sm(z) file;
  • Functionality of the " " (space) key fixed in case when no plug-in for Text Region is available;
  • equrep() function supports variables/functions replacements now.
Miscellaneous
  • Support for .Net Core 3.1 implemented (app is still released supporting .Net 2.0 for now);
  • Refactoring.
Download
SMathStudioDesktop.0_99_7542.Mono.tar.gz (1 MiB) downloaded 926 time(s).
SMathStudioDesktop.0_99_7542.Setup.msi (2 MiB) downloaded 3327 time(s).
10 users liked this post
Вячеслав Мезенцев 8/25/2020 1:18:00 AM, sergio 8/25/2020 4:55:00 AM, Denis Nikitin 8/25/2020 6:41:00 AM, IVR 8/25/2020 9:16:00 AM, NDTM Amarasekera 8/25/2020 11:51:00 AM, Arie 8/25/2020 12:38:00 PM, frapuano 8/26/2020 3:32:00 AM, Serg 8/26/2020 11:34:00 AM, Davide Carpi 8/28/2020 2:36:00 PM, Василий Николаевич Храмушин 9/20/2020 9:58:00 AM
#2 Posted: 8/25/2020 6:26:19 AM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
992 likes in 1674 posts.
Hi. Thanks! Very much!
"equrep() function supports variables/functions replacements now."
Any example about what that means?
Also, I see that this error persists:
#3 Posted: 8/25/2020 6:07:08 PM
Hello Alvaro!
Yes, this is a main reason why I can't release stable version of SMath Studio now. I'm working on this issue right now.
Alvaro Diaz Falconi 8/25/2020 8:27:00 PM
#4 Posted: 8/27/2020 5:11:26 PM
983 likes in 6866 posts.
Any example about what that means ?
Can you show an application of it ?
An image is good enough.
Thanks ... Jean
#5 Posted: 8/27/2020 9:24:31 PM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Thanks ... Jean
Hi Jean. Here: Applications for equrep: expression isolation and laplace transform.
IVR 8/29/2020 12:29:00 PM, frapuano 8/28/2020 2:53:00 AM
#6 Posted: 8/29/2020 6:54:30 AM
Thanks ... Jean
Just to make it clear: equrep() function is not something I'm spending time on to create/support/improve. This function appeared as a demo of the updated symbolic core of SMath Studio. This function is an interface to the new functionality. You can use it or not, but it demonstrates possibilities of the symbolic simplifications SMath Studio provides.
Unfortunately it has at least one issue which is hard to fix. I'm doing my best to remove a bug, but if it will be too hard maybe I will revert my changes and use stable (which is used in latest stable version of the application) symbolic core again.
So it is not about equrep() function it is about core of the program, its performance, possibilities, behaviors etc. If you are remember, all the calculations in SMath Studio goes through symbolic optimization, so it is pretty important.
4 users liked this post
sergio 8/29/2020 12:58:00 PM, Serg 8/30/2020 9:20:00 AM, IVR 8/29/2020 12:29:00 PM, frapuano 8/29/2020 12:34:00 PM
#7 Posted: 8/30/2020 12:12:30 PM
Thanks Alvaro ... always there in Smath Community !
BTW Andrey, if/else, if/otherwise have not been observed
detrimental in timing in general applications.
For this application [Julia], timing kills Smath ... Oh !
OK, my Win 7 1.66 GHz is steam engine.
What about your latest Beta SS 7542 ?
Thanks ... Jean
Pattern Julia Set [PUBLISH].sm (172 KiB) downloaded 94 time(s).
#8 Posted: 8/30/2020 4:33:41 PM
554 likes in 1333 posts.
Maybe it is a bug maybe intended I don't know;
On 7542 for underlined text regions, spaces are not underlined.
No problem for letters, numbers, punctuations, etc.
Writer regions don't have this issue.
#9 Posted: 9/9/2020 12:12:34 PM
1222 likes in 2150 posts.
I can't switch on/off any more the border of image regions (and also fo Maxima draw regions) in 7542.
In 7251 this still works. It also works for documents produced in 7542.
#10 Posted: 9/9/2020 7:32:12 PM
Thank you! Fixed.
#11 Posted: 9/9/2020 7:33:22 PM
I can't reproduce this issue locally. Please could you upload a files (one with correct behavior and another with incorrect)?
#12 Posted: 9/10/2020 7:16:24 AM
I attach two files. The first one is created in 7542. No matter what I do in the contex menu, the border can't be switched off. Neither is there a change in the GUI, nor is the xml attribute changed.
If I load this file in 7251, then I can switch off the border, this is both visible on the canvas and in the xml entry.
Once I save that (second file), this can be opened by 7542 and the change is respected. And you guess it, the border can't be switched on again. Thus, actually there is no wrong file, just wrong GUI behaviour.
7542 displays existing files correctly. Just no access to this one setting.
I leave out the maxima draw region, as this might prevent reproduction without maxima installation.
border 7542.sm (7 KiB) downloaded 87 time(s).
border 7542 then 7251.sm (7 KiB) downloaded 84 time(s).
Andrey Ivashov 9/13/2020 7:33:00 AM
#13 Posted: 9/13/2020 7:35:16 AM
Thank you very much. Fixed now.
There is one issue with the plug-in: invalidation of the region is not requested after menu item usage (it must be done by plug-in) so borders will be visually switched only after region redrawn, f.e. after scrolling or focus in/out.
Martin Kraska 9/13/2020 6:42:00 PM
#14 Posted: 9/13/2020 4:55:14 PM
Issue is fixed in the latest stable version I have just published. equrep() made less powerful, so it will leave an equation as is in cases where error is possible. Like your example.
This is temporary solution but it is required to continue development without serious stoppers. In future I will continue working to make symbolic engine more smart.
Alvaro Diaz Falconi 9/13/2020 5:11:00 PM
#15 Posted: 9/13/2020 7:00:12 PM
This also seems to be the cause for delayed re-draw after editing operation (you have to get focus off the image to see the changes). Very valuable hint!
Filed in the bug tracking system as SS-4640
#16 Posted: 9/16/2020 6:43:50 PM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
I post that question because interpret that then equrep works replacing f by sin in this example: "equrep(3+f(x),f,sin)=3+f(x)" but now I see that the correct way is "equrep(3+f(x),f(a),sin(a))=3+sin(x)"
Here my attempt to convert an expression with operators to an expression with binary or unary functions only
_to_expr.sm (51 KiB) downloaded 83 time(s).
_to_expr.pdf (223 KiB) downloaded 94 time(s).
#17 Posted: 10/30/2021 8:11:38 PM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Rematch ... It's seems to work now.
num2expr.sm (39 KiB) downloaded 83 time(s).
num2expr.pdf (176 KiB) downloaded 95 time(s).
sergio 10/31/2021 12:37:00 PM
  • New Posts New Posts
  • No New Posts No New Posts
