SpiceSharp
SpiceSharp - Spice# electronic circuit simulator - Messages
#1 Posted: 11/22/2024 7:14:57 AM
1402 likes in 1708 posts.
SpiceSharp (Spice#) - electronic circuit simulator
SMath Studio compatibility Sources
Based on SpiceSharpParser (.NET library that allows to parse SPICE netlists and to simulate them using SpiceSharp library).
This plugin requires .Net Framework 4.7.2 to be installed for it to work.
I managed to run the first test example on my PC. The plugin is not available on the server yet.
Links:
1. SpiceSharpParser
2. SpiceSharp Home Page
Alvaro Diaz Falconi 11/23/2024 12:03:00 PM
#2 Posted: 11/22/2024 7:30:22 AM
For experts only.
spice#.sm (5 KiB) downloaded 64 time(s).
Plugins folder: C:\Users\User\AppData\Roaming\SMath\extensions\plugins
SpiceSharp-0.1.9092.9246.zip (10 MiB) downloaded 64 time(s).
Alvaro Diaz Falconi 11/22/2024 12:54:00 PM, francesco rapuano 11/22/2024 7:42:00 PM
#3 Posted: 11/25/2024 12:45:27 PM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
992 likes in 1674 posts.
Hi. A preview for exploring this powerful plugin.
spice# and MNA.sm (577 KiB) downloaded 65 time(s).
spice# and MNA.pdf (1 MiB) downloaded 83 time(s).
Вячеслав Мезенцев 11/25/2024 1:05:00 PM
#4 Posted: 11/25/2024 1:05:39 PM
I haven't even tried these features myself yet. Support for all types of analysis hasn't been tested. There's still a lot of work to do. Maybe I'll do a direct insertion of values ​​into the circuit description. I wanted to try making a circuit with an amplitude detector. The authors have recently added the ability to specify an amplitude-modulated signal. They have a shell (GUI) in which you can also test circuits.
#5 Posted: 11/25/2024 1:23:12 PM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi Viacheslav. As far as I could see, the plugin you created works very well, it just has some very minor details, like not recognizing either "u" or "μ" for micro. By the way, handling that is a configurable option in ltspice. So you shouldn't be the first one to have problems with that.
As for the analyses that spice# has, it's just a matter of discovering them, since the documentation they have is very little, and for example, I don't know what convention they followed to enumerate the nodes of the controlled sources. I took the one they use in the Qucs simulator, but there is no standard for that.
I saw the GUI for windows that you mention on github, except that they didn't compile it... or at least I didn't find it, only the source code.
Вячеслав Мезенцев 11/25/2024 3:22:00 PM
#6 Posted: 11/25/2024 3:21:40 PM
Similar project. I assembled it, but I haven't tried it in work.
NextGenSpice_20241125.zip (321 KiB) downloaded 60 time(s).
Links:
1. NextGenSpice/Program.cs
2. NextGenSpice/plot.ps1
Alvaro Diaz Falconi 11/25/2024 11:42:00 PM
#7 Posted: 12/1/2024 10:51:11 AM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
New version, more compatible with spice# sintaxis.
spice# and MNA v2.sm (636 KiB) downloaded 57 time(s).
spice# and MNA v2.pdf (1 MiB) downloaded 83 time(s).
Вячеслав Мезенцев 12/1/2024 11:52:00 AM
#8 Posted: 12/10/2024 1:23:50 AM
A task for implementation in the future:
Практический расчет параметров индуктивности
https://forum.cxem.net/index.php?/topic/270218-практический-расчет-параметров-индуктивности/
#9 Posted: 1/11/2025 4:41:49 PM
SMath Studio compatibility Changes
Plugin updated.
Changes:
- Plugin adopted to a new SMath Studio Core infrastructure;
- Folders removed from the output artefacts.
4 users liked this post
Andrey Ivashov 1/11/2025 5:00:00 PM, Oscar Campo 1/11/2025 5:46:00 PM, Davide Carpi 1/11/2025 7:57:00 PM, Alvaro Diaz Falconi 1/12/2025 3:48:00 PM
  • New Posts New Posts
  • No New Posts No New Posts
