Add a Force Density, or Unit Weight, Dimension
Add a Force Density, or Unit Weight, Dimension - Messages
#1 Posted: 4/25/2014 2:50:23 PM
Ricyteach
Ricyteach
1 likes in 14 posts.
I am attempting to add my own custom unit of pound force per cubic foot (pcf) to the Units.xml file; however, there does not appear to be a dimension available for Force Density (sometimes referred to as "Unit Weight" ) .
Adding this line to Units.xml results in an error:
Is there a way I can accomplish this on my own or does the source code need to be modified...?
Thanks.
#2 Posted: 4/29/2014 4:02:53 PM
2271 likes in 3736 posts.
Hello. Next version of SMath Studio will allow to set your own dimension XML file. Currently it is not possible.
Davide Carpi 4/29/2014 5:14:00 PM
#3 Posted: 5/7/2014 9:40:43 AM
Ricyteach
Ricyteach
This is great news! Thank you for the update!
#4 Posted: 9/25/2014 8:09:09 AM
Ricyteach
Ricyteach
Andrey, did this feature make it into the latest version as planned? If so, what does a user-defined xml dimension file look like? What are the rules for creating one so I can add units for force-density, for example?
#5 Posted: 9/25/2014 11:43:53 AM
1222 likes in 2150 posts.
Have a look at the file ufhb.xml in the entries directory of the portable distribution. The added dimensions are documented in the interactive handbook [?]> Units of measurement> New units in the inofficial SMath distribution.
Some of these units are language-sensitive.
As the required force density just would add units to the pressure dimension, this should be straightforward.
#6 Posted: 9/25/2014 12:03:23 PM
Ricyteach
Ricyteach
Thanks! I'll have a look at both of those.
Maybe I misunderstand, but force density isn't just adding units to the pressure dimension, is it? Since pressure is FORCE/LENGTH^2 and force density is FORCE/LENGTH^3. Smath didn't have the ability to add user defined units for FORCE/LENGTH^3 before. You are saying that after looking at the above references I should be able to add them now?
#7 Posted: 9/25/2014 1:09:05 PM
Sorry, I just didn't read the previous posts carefully and assumed you were asking for force/area. I added "quantity" units, but to be honest, I forgot, why I used dimension="613". Mostly just try and error. Thus, for force/volume I am not that confident.
#8 Posted: 9/25/2014 1:27:00 PM
Ricyteach
Ricyteach
When I get time I'll give it a try using 613. Hopefully Andrey will be able to let us know if he ended up including this capability in the latest release (it isn't listed in the update log at the forum download thread).
  • New Posts New Posts
  • No New Posts No New Posts
