Solve for Unknowns
Solve for Unknowns - 9 Equations, 9 Unknowns - Messages
#1 Posted: 1/16/2018 4:57:54 PM
Norm Schutzkus
Norm Schutzkus
9 likes in 90 posts.
Transferring a MC sheet. How can I solve for the unknowns?BJT Circuit Analysis.sm (54 KiB) downloaded 93 time(s).
#2 Posted: 1/16/2018 5:48:31 PM
Arie
Arie
93 likes in 285 posts.
For using Linsolve(1) function, you need to put the system of equations into a matrix. The result computes the unknowns in alphabetical order, I believe. You can retrieve this information using Unknowns function.
BJT Circuit Analysis.sm (63 KiB) downloaded 108 time(s).
#3 Posted: 1/16/2018 6:45:55 PM
Norm Schutzkus
Norm Schutzkus
Many thanks!
#4 Posted: 1/16/2018 10:15:48 PM
983 likes in 6866 posts.
Unknowns("variable") - ... from f(x) menu
Returns a vector of unassigned variables contained in "1:variable".
If unknowns are not found, returns 0.
Solutions are returned in lexicographic order ... inspect Unknowns(A)
#5 Posted: 1/16/2018 11:41:57 PM
... thanks for this LinSolve application.
Maths LinSolve.sm (69 KiB) downloaded 138 time(s).
#6 Posted: 1/17/2018 4:03:40 AM
Here is another MCD sheet, converted Smath [circuit application].
Iterative solvers are common in Engineering.
Solve TREASURY_1 [Iterate L, Lc].sm (58 KiB) downloaded 116 time(s).
#7 Posted: 1/17/2018 10:33:57 AM
Norm Schutzkus
Norm Schutzkus
Thanks Jean, for the Solve Treasury worksheet. I updated my sheet splitting the ampere and voltage values apart.
Best regards,
NormBJT Circuit Analysis.sm (49 KiB) downloaded 89 time(s).
#8 Posted: 1/17/2018 11:07:30 AM
Arie
Arie
I've modified the LinSolve(1) function and created a LinSolve2(2) function that allows user to specify result order vector. I've named it LinSolve2 to avoid confusion with the LinSolve(2) Maxima Plugin function.
Not sure if this is useful for anyone.
BJT Circuit Analysis (1).sm (86 KiB) downloaded 104 time(s).
#9 Posted: 1/18/2018 1:23:34 AM
Lovely separation of result.
A useful companion attached, more examples in future.
Solve LinSolve COMPANION.sm (31 KiB) downloaded 112 time(s).
#10 Posted: 1/18/2018 9:35:41 AM
Arie
Arie
Quote
Jean, I believe the original LinSolve function is a snippet created by Martin (mkraska). You can find it within the Snippet Manager in SMath.
#11 Posted: 1/19/2018 12:07:33 PM
I think so ... those gyzmas # are Martin style.
Easy to removed all # ... like this
1. start by the LHS in the program definition
2. put the cursor on the right of the #
3. press F8 to see all selected, in the program core as well
4. once selected, press Backspace ... gone
5. next proceed in the core of the program
6. result => nice and clean
Cheers
  • New Posts New Posts
  • No New Posts No New Posts
