Create a graph with x-y plot
Create a graph with x-y plot - Messages
#1 Posted: 2/11/2023 6:35:47 AM
Beyaz
Beyaz
0 likes in 19 posts.
Hey guys,
im trying to plot my function with x-yplot (addon) but it doesnt work. I will be happy if can someone can help me.
i define two functions (with If-clauses) and now I have to put it in x-y-plot.
Thanks for helping
Pfahlsetzungslinie.sm (101 KiB) downloaded 67 time(s).
#2 Posted: 2/11/2023 9:51:05 AM
983 likes in 6866 posts.
I define two functions (with If-clauses) and now I have to put it in x-y-plot.
1. Start by the first red instance ... assign the demand.
2. For the plot Units don't match
3. Check if your incomplete Bolean is OK ... here shown complete.
4. What is mPa
#3 Posted: 2/11/2023 11:27:05 AM
554 likes in 1333 posts.
If you want to plot, you have to eliminate units.
Either by writing a unitless function, or using units while plotting.
I would rather second one.
Pfahlsetzungslinie.sm (112 KiB) downloaded 56 time(s).
Click to enlarge
#4 Posted: 2/11/2023 2:22:20 PM
Beyaz
Beyaz
hey guys thanks. (i tryed to give you a thanks but i always get an error)
it works now. Ive realized my mistakes.
i have 2 more question.
1. is it possible to rotate the graph or function? I wanna switch x and y axis
2. i wanna make the visible spectrum of x and y axis depent on a variable. like X-Axis Max=s1 and Min=s2
//sorry for my bad english
#5 Posted: 2/11/2023 4:44:13 PM
2. I wanna make the visible spectrum of x and y axis depend on a variable. like X-Axis Max=s1 and Min=s2
I understand 1 ... 2 Not clear.
#6 Posted: 2/11/2023 4:46:06 PM
... once the discrete data set in hand,
you can rotate by any angle as desired.
#7 Posted: 2/11/2023 5:58:06 PM
If I understand: once the discrete data set in hand,
very easy to range between Mi/Max.
Produce the discrete data set, I will terminate.
#8 Posted: 2/12/2023 1:43:27 AM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
992 likes in 1675 posts.
... i have 2 more question.
Hi Beyaz.
1. Yes. For example you can use this technique over your functions
xy-yx-plot.sm (7 KiB) downloaded 56 time(s).
2. Yes. For example you can try to learn about how to use setprop in an XY plot region.
#9 Posted: 2/12/2023 7:09:44 AM
Beyaz
Beyaz
question 2: solved after find this
https://en.smath.com/forum/yaf_postsm57205_X-Y-Plot-Region.aspx
but to rotate the graph like this it didnt work. i tried your suggestions. Pfahlsetzungslinie1.sm (80 KiB) downloaded 58 time(s).
#10 Posted: 2/12/2023 8:47:18 AM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi. You need to specify the XYPlot index. This is how to swap axis coordinates, and reverse the y-axis. I reduce the number of points in the XYPlot to 50.
Pfahlsetzungslinie1.sm (87 KiB) downloaded 67 time(s).
#11 Posted: 2/12/2023 9:12:08 AM
But to rotate the graph like this it didn't work.
I tried your suggestions.
You haven't produced the discrete data set.
Wanna Rotate.sm (14 KiB) downloaded 46 time(s).
#12 Posted: 2/12/2023 2:23:09 PM
#13 Posted: 2/13/2023 7:13:49 AM
You can also use a rotation matrix.
It works on both 2DPlot an XYplot.
churichuro 2/13/2023 4:11:00 PM
#14 Posted: 2/13/2023 10:41:33 AM
Rotate XY.sm (486 KiB) downloaded 48 time(s).
#15 Posted: 2/13/2023 3:07:49 PM
Beyaz
Beyaz
thanks all of you guys.
now my smath tool is perfect. thanks for helping.
  • New Posts New Posts
  • No New Posts No New Posts
