2D Plot Vectorised vector
2D Plot Vectorised vector - Not sure this is possible - Messages
#21 Posted: 1/21/2021 1:02:40 PM
983 likes in 6866 posts.
Not sure why you cannot open.
It is a persisting random bug, from unknown.
Windows not recognizing *.sm format, at random and why.
That bug has not been isolated ... Russian Roulette ?
#22 Posted: 1/22/2021 4:09:05 AM
Fridel Selitsky
Fridel Selitsky
520 likes in 451 posts.
A good way is to work units-less, then append silent units.
Calculation without units. Units are presented at the end of the calculation
Heate.sm (9 KiB) downloaded 56 time(s).
#23 Posted: 1/22/2021 11:28:29 AM
Ruben Sidranski
Ruben Sidranski
17 likes in 463 posts.
Ber7,
Still off by a factor of units (12 to convert inches to ft). I split this to a NEW TOPIC. I've never used the Mat2System function.
#24 Posted: 1/22/2021 11:46:23 AM
Thanks Ber7, nice sterilized units
Heate 6179.sm (14 KiB) downloaded 55 time(s).
#25 Posted: 1/22/2021 11:49:28 AM
Ruben Sidranski
Ruben Sidranski
But it's wrong
#26 Posted: 1/22/2021 12:05:10 PM
But it's wrong
Just divide something by 12
#27 Posted: 1/22/2021 12:08:24 PM
Ruben Sidranski
Ruben Sidranski
That's the problem. Units are important and impact the way the function is not working. Divide t by 12 and the The x column no longer starts with 4, but 1/3 and the y column is correct. Leave it as is and the x column is correct and the y column is wrong.
#28 Posted: 1/22/2021 1:09:45 PM
I love Ber7 method, saved it personal.
Easy to scale/reconciliate from your original by 'λ'
Unit Waterloo Otherwise.sm (15 KiB) downloaded 47 time(s).
#29 Posted: 1/22/2021 1:27:55 PM
Fridel Selitsky
Fridel Selitsky
In dimension Ro there is a ft. Therefore, the size t
should be expressed in ft. The bug has been fixed.
Heate in-ft.sm (9 KiB) downloaded 47 time(s).
#30 Posted: 1/22/2021 2:34:41 PM
Therefore, the size tshould be expressed in ft.
Wait and watch what Elsid will comment !
Units system is really a Monkey Business, isn't ?
#31 Posted: 1/22/2021 2:49:53 PM
Ruben Sidranski
Ruben Sidranski
Correct, divide by 12 ... in this case.
This elegant function appears to work on all empirical equations, as long as the user input units are double checks for consistent cancellation.
Is the descriptor of the function accurate? Heat Capacity Function_Sys2Mat Ber7.sm (15 KiB) downloaded 79 time(s).
#32 Posted: 1/23/2021 2:51:29 PM
Fridel Selitsky
Fridel Selitsky
Change your file a bit and added clarifications
Heat t Ber7.sm (16 KiB) downloaded 63 time(s).
ElSid 1/23/2021 7:07:00 PM
  • New Posts New Posts
  • No New Posts No New Posts
