1 Pages (15 items)
Implicit Plot - Messages
#1 Posted: 2/19/2018 12:34:45 AM
Hi. I'm trying to implement this implicit plot. But can't "cut" the lines in the xy plot. Also, any help about speeding the function is welcome.
iplotq.sm (40 KiB) downloaded 172 time(s).
#2 Posted: 2/19/2018 4:35:55 AM
#3 Posted: 2/19/2018 6:07:23 AM
Hi Ber. Thanks for the implementation. But it use maple and is semisymbolic, I want just some that can works in the cloud, like: https://en.smath.info/cloud/sheet/s23Pa6bZUn
#5 Posted: 2/19/2018 7:13:37 AM
Perfect! Thanks.
#6 Posted: 2/19/2018 7:22:41 PM
#7 Posted: 2/19/2018 9:28:12 PM
Hi Carlos
For see the error message type B1=
#8 Posted: 2/19/2018 11:44:57 PM
#9 Posted: 2/22/2018 3:11:16 AM
Hola Carlos. Try the following, a short version, just for n=2.
DragilevMet2.sm (12 KiB) downloaded 97 time(s).
Fridel Selitsky 2/22/2018 4:44:00 AM
#10 Posted: 2/22/2018 4:21:24 AM
Try also the old version of the Draghilev method
DragilevMet3.sm (23 KiB) downloaded 88 time(s).
Razonar,thanks for the short code for n = 2
#11 Posted: 2/22/2018 2:45:42 PM
Carlos, Alvaro,
From previous use of Dragilev method, I observed great difficulties
to appropriately start/stop rkfixed. Your example above works fine as is.
For more points with less tentatives in specific cases, the easiest way
is to pass it to the closed shape Hermite suite.
I should revisit some of those examples.
The Esplina AI2000 interpolates as well for closed shapes.
Spline Esplina [AI2000].sm (21 KiB) downloaded 81 time(s).
Spline Esplina [Hermite].sm (35 KiB) downloaded 89 time(s).
Fridel Selitsky 2/22/2018 3:50:00 PM
#12 Posted: 2/22/2018 3:55:44 PM
By--> Razonar
By--> Ber7
Hola Alvaro, Hello Ber7,
Thanks for your reply, but the DragilevMet2 and 3 files do not work.
The file of Ber 7 does not show any error, but by requiring the value
of B1 and B2, it says that "x" is not defined.
Attached drawing of the errors.
Hello Jean, your files worked perfectly.
Carlos
QuoteHola Carlos. Try the following, a short version, just for n=2
By--> Ber7
QuoteTry also the old version of the Dragilev method
DragilevMet3.sm (24kb) downloaded 10 time(s)
Carlos
#13 Posted: 2/23/2018 3:19:44 AM
Hola Carlos.
It's because a problem with rkfixed routine in your environment. Try to download this, or use it in the cloud: DM_RK
#14 Posted: 2/23/2018 3:56:57 PM
#15 Posted: 2/23/2018 11:30:39 PM
Hola Alvaro
Here too, the problem is caused by the decimal separator "Point",
Changing in options, the decimal separator from "Point" to "Comma", (from "." To ",")
resolves the problem of graphing
Carlos
Carlos
Alvaro Diaz Falconi 2/24/2018 6:48:00 PM
1 Pages (15 items)
New Posts
No New Posts
