1 Pages (9 items)
Units don't match problem - Messages
#1 Posted: 8/6/2016 1:09:41 PM
Hi everybody, I have a units problems that I can´t solve. Can be a bug?
Here is my file.
Documento1.sm (29 KiB) downloaded 56 time(s).
Libro2.xlsx (8 KiB) downloaded 48 time(s).
Thanks in advance
Eduar
Here is my file.
Thanks in advance
Eduar
#2 Posted: 8/6/2016 1:42:29 PM
Hello Eduar,
nope, is not a bug; the problem is in your second boolean comparison. You have nested a boolean less or equal in the left argument of a boolean less -> the first returns 0 and 1, then this result is compared with the second argument of the boolean less (and here you were lucky because you got 1 - when you get 0 you can't see the error)
![2016-08-06 18_34_31-SMath Studio Desktop - [Documento1.sm].png](/en-US/file/ATmBGx/2016-08-06-18_34_31-SMath-Studio-Desktop---_Documento1_sm__png)
You have to use the boolean AND to chain two boolean comparisons
![2016-08-06 18_37_51-SMath Studio Desktop - [Documento1.sm_].png](/en-US/file/CBNBPo/2016-08-06-18_37_51-SMath-Studio-Desktop---_Documento1_sm___png)
Alternatively it is possible to use the function lelt(3) from the plug-in "Custom Functions"
#3 Posted: 8/6/2016 1:57:06 PM
Thanks Davide, I´ll try it.
And thank you for the plugin.
Eduar
Eduar
#4 Posted: 8/6/2016 2:46:02 PM
WroteThanks Davide, I´ll try it.
Eduar
Hi Davide, your method works fine. But I still have problems with the resolution of the division.
I don't understand, the result is a vector.
Sorry for the question, I'm a newbie in Smath.
#5 Posted: 8/7/2016 5:25:18 AM
Don't worry; vectorize() is intended to apply to all the vectors' elements functions normally intended to work with scalars without using loops. In your case you have 2 ways:
1) use the loop; in this case vectorize() is not needed, remove it and everything should works
![2016-08-07 10_21_27-SMath Studio Desktop - [Documento1.sm_].png](/en-US/file/FTUWaw/2016-08-07-10_21_27-SMath-Studio-Desktop---_Documento1_sm___png)
2) use vectorize(); in this case you have to remove all the references to the matrix elements. Note that in your case you have to pre-process or post-process the elements where Mu doesn't meets the requirements
![2016-08-07 10_21_37-SMath Studio Desktop - [Documento1.sm_].png](/en-US/file/KuFCs3/2016-08-07-10_21_37-SMath-Studio-Desktop---_Documento1_sm___png)
Eduardl 8/8/2016 3:33:00 PM
#6 Posted: 8/7/2016 8:55:06 AM
WroteDon't worry; vectorize() is intended to apply to all the vectors' elements functions normally intended to work with scalars without using loops. In your case you have 2 ways:
You are right!
Thank you Davide.
I hope I can contribute to the community in the future.
Eduar
#7 Posted: 8/9/2016 11:39:29 AM
EduardI,
If you have to select elements in the vectorise,
the Dot function may be the tool... just posted.
#8 Posted: 8/9/2016 11:44:18 AM
Jean, thanks for the tip. I'm learning fast thanks to you guys!
#9 Posted: 8/10/2016 12:36:46 AM
"Jean, thanks for the tip. I'm learning fast thanks to you guys!"
How do you know you are learning fast ? !
This type of indexed construction has many variantes, most useful.
For instance: randomly select reasonable number of data points from
an overpopulated collection to be fitted ...
1 Pages (9 items)
New Posts
No New Posts
