Matlab Runtime Library
Matlab Runtime Library - Consists of approximately 400 Matlab math functions - Messages
#81 Posted: 8/20/2019 6:57:04 AM
1402 likes in 1708 posts.
As I see, we can use Matlab Runtime instead of current solution. Using it, we can get a 64-bit version of the plugin.
frapuano 8/20/2019 9:53:00 AM
#82 Posted: 1/8/2022 11:25:51 PM
SMath Studio compatibility Platform
Plugin updated. Only the 32-bit version is available.
Changes:
- plugin renamed to Matlab Runtime Library;
- converting the task for the ODE solvers to the numerical form is now performed through the Mathcad Toolbox plugin (to avoid code duplication), so it must be installed;
- totally refactored.
#83 Posted: 1/10/2022 5:29:42 AM
Andrey
Andrey
1 likes in 44 posts.
Dear Viacheslav,
thank you for the plugin.
Can I ask a quick question?
Does it work only with the older version?
By me, unfortunately, this plugin is not accessible.
Best regards,
Andrey
#84 Posted: 1/10/2022 5:41:40 AM
You need to switch the program to 32-bit mode. This is an old library and didn't exist at that time in 64-bit form. That is why I additionally pointed it out.
You must manually change the bitness of the executable file in administrator mode. After that, the library will become available.
CorFlags will help you to use this plugin on 64-bit system.
32-bit ON: CorFlags /32bit+ Solver.exe or CorFlags /32bit+ SMathStudio_Desktop.exe
32-bit OFF: CorFlags /32bit- Solver.exe or CorFlags /32bit- SMathStudio_Desktop.exe
CorFlags.zip (141 KiB) downloaded 69 time(s).
Davide Carpi 1/11/2022 7:07:00 AM, Andrey Ivashov 1/11/2022 3:28:00 PM, Oscar Campo 10/14/2022 8:52:00 AM
#85 Posted: 1/11/2022 5:53:20 AM
Andrey
Andrey
Hallo Viacheslav,
thnak you for your help and your quick reply!
Best regards,
Andrey
#86 Posted: 10/14/2022 2:10:58 PM
Oscar Campo
Oscar Campo
124 likes in 298 posts.
Any news of using this runtime on 64 bits version?
#87 Posted: 10/14/2022 4:35:37 PM
It differs in structure and I can't find examples of how to use it separately from matlab. In addition, the size of the distribution is much larger.
I will have to start all over again for the new version of matlab engine.
Oscar Campo 10/14/2022 5:07:00 PM
  • New Posts New Posts
  • No New Posts No New Posts
