MathRegion Critical Error on DEL key action
MathRegion Critical Error on DEL key action - Messages
#1 Posted: 1/13/2022 2:39:53 PM
Igor Skarine
Igor Skarine
14 likes in 97 posts.
Eventually I have caught a bug that bothered me in a few latest versions of Smath.
critical_bug.sm (3 KiB) downloaded 77 time(s).
Try to delete the first number "4" in front of the ratio.
Step 1: Select it with the cursor.
Show Spoiler
Step 2: Press "Del", the "4" turns into a black square.
Show Spoiler
Step 3: Press "Del" once again. SM pops on "Critical error".
Show Spoiler
Davide Carpi 1/14/2022 4:08:00 AM
#2 Posted: 1/13/2022 6:06:39 PM
Igor Skarine
Igor Skarine
Jean,
It can't be doctored, it is not a calculation issue.
Smath Studio crashes at the moment you push "DEL" key to delete this number "4" or whatever else there.
#3 Posted: 1/13/2022 7:31:57 PM
churichuro
churichuro
28 likes in 79 posts.
I confirm the error
#4 Posted: 1/13/2022 10:05:45 PM
1402 likes in 1708 posts.
Confirmed. I also came across it, but I didn't investigate it. SMath Studio 0.99.7921.69.
#5 Posted: 1/14/2022 1:54:58 AM
554 likes in 1333 posts.
confirmed under linux.
same behavior.
#6 Posted: 1/14/2022 5:59:07 AM
1417 likes in 2873 posts.
Thank you, confirmed
System.IndexOutOfRangeException: Index out of matrix bounds.
   in SMath.Controls.MathPainter.PrepareForPaint(MathRegion region, PaintContext ctx, Term[] input, MathAnswer answer, Term[] units, Boolean inputDataVisibility, Int32 currentTermIdx, FontInfo font, Boolean focused, Single& middleLine, Single& baseLine)
   in SMath.Controls.MathRegion.(IGraphics , PaintEventOptions )
   in SMath.Controls.MathRegion.OnCommandSend(String value)
   in SMath.Controls.WorksheetEditor.(RegionBase , String )
   in SMath.Controls.WorksheetEditor.InsertManager(String value)
   in SMath.Controls.Worksheet.Insert(String value)
   in SMath.Controls.WorksheetEditor.KeyDown(KeyEventOptions e)
   in SMath.UI.Accessories.DesktopWorksheet.OnKeyDown(KeyEventArgs e)
   in System.Windows.Forms.Control.ProcessKeyEventArgs(Message& m)
   in System.Windows.Forms.Control.WmKeyChar(Message& m)
   in System.Windows.Forms.Control.WndProc(Message& m)
   in System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
#7 Posted: 1/14/2022 10:59:14 AM
... end of it !
It didn't surprise me that Jean couldn't understand what the bug is.
Alvaro Diaz Falconi 1/14/2022 12:39:00 PM
#8 Posted: 1/14/2022 11:32:56 AM
Jean, what you're trying to do here is destructive. You prevent users from helping developers improve the program, that is, you bring harm. You don't have to do that. This is not good.
6 users liked this post
Oscar Campo 5/17/2022 12:41:00 PM, churichuro 1/14/2022 2:38:00 PM, sergio 1/14/2022 3:05:00 PM, overlord 1/14/2022 11:57:00 AM, Alvaro Diaz Falconi 1/14/2022 12:39:00 PM, fedeghi 1/14/2022 4:43:00 PM
#9 Posted: 1/14/2022 2:17:41 PM
Jean, in the exUSSR there was such a norm as forced rest. People who worked hard were forced to rest in a sanatorium. And their leaders, who allowed this, were punished. I think you need to go to a sanatorium and temporarily stop working here. I don't want to be punished and I can give you a rest.
4 users liked this post
NDTM Amarasekera 1/14/2022 10:41:00 PM, fedeghi 1/14/2022 4:43:00 PM, overlord 1/14/2022 2:23:00 PM, Alvaro Diaz Falconi 1/14/2022 3:55:00 PM
#10 Posted: 1/14/2022 4:04:25 PM
Basically up to SS 6179, Smath is an equation editor
working similar to Mathcad 11 and earlier, including program.
AFAIK, an option for script style [typical Kalkulator ...]
will manage the critical error demo bug.
Is it possible to combine both: part script style & equation editor ?
As well as accommodate both styles in program ?
And yet another useless not related post again.
Unbelievable. Wow, just wow.
Such ignorance, such obstinate, such thick head...
I am out of speech right now.
fedeghi 1/14/2022 4:45:00 PM, NDTM Amarasekera 1/14/2022 10:42:00 PM, Oscar Campo 5/17/2022 12:40:00 PM
#11 Posted: 5/16/2022 12:06:43 PM
Igor Skarine
Igor Skarine
Unfortunately,
The "Critical Error on Del key action" was not fixed yet in the latest stable version.
Try to delete "g" by using DEL key.
oldbug.sm (2 KiB) downloaded 71 time(s).
#12 Posted: 5/17/2022 8:38:34 PM
2270 likes in 3734 posts.
Ok, will check asap.
Davide Carpi 5/18/2022 4:42:00 AM
#13 Posted: 6/16/2022 8:29:35 PM
⚜ Kenny Lemens, P.E. ᵂᴵ
74 likes in 164 posts.
Greetings!
I can also confirm the existence of this issue ( "v0.99.7921.69" ). Upon investigation, I have (2) items:
  1) The program does not actually 'crash', the program is still running. Thus: you can recover from this bug without losing all your work!
      a) To recover from this error:
            1) On the " Unhandled exception has occurred ... Index was outside the bounds of the array" popup error message, Click on the button: 「Continue」
            2) 'UNDO' your last action, either via the menu bar: 「Edit」 -> 「 Undo」 or via keypress 「Ctrl」 + 「Z」
            3) Repeat steps #1 and #2 until you achieve a successful 'undo'.
  2) The elements of this error seem to require a grouping operator (e.g., Absolute Value, Parenthesis, Determinant, Square Root, Matrix) that is paired with a fraction/division operation, prepend this with a multiplication statement and you can duplicate the error. See screen capture below:
Below are a few statements I compiled; performing the double-delete on the integer '6' will throw the same error:
-Kenny Lemens, P.E.
#14 Posted: 6/23/2022 11:31:02 AM
Greetings,
I found another configuration that can trigger this error; if you declare/evaluate a variable, and then try to multiply that entire set: you get a syntax error. Now if you attempt to correct the statement by using the [DEL] to remove the evaluation, the error gets thrown (as shown below):
The work around would be to use the [Backspace] to delete/correct the equation, or to copy/paste the terms into a new statement without syntax errors.
-Kenny Lemens, P.E.
Davide Carpi 6/23/2022 2:21:00 PM
#15 Posted: 7/22/2022 5:33:42 PM
Finally fixed in version 1.0.8238.
⚜ Kenny Lemens, P.E. ᵂᴵ 7/22/2022 5:41:00 PM, João Felipe Seráfico Melo 7/22/2022 6:02:00 PM, sergio 7/23/2022 5:37:00 AM
#16 Posted: 4/13/2023 10:40:14 AM
salmawisoky
salmawisoky
0 likes in 2 posts.
Greetings,
I found another configuration that can trigger this error; if you declare/evaluate a variable, and then try to multiply that entire set: you get a syntax error. Now if you attempt to correct the Candy Crush statement by using the [DEL] to remove the evaluation, the error gets thrown (as shown below):
-Kenny Lemens, P.E.
I tried that .... still get the error
  • New Posts New Posts
  • No New Posts No New Posts
