extract a row from an iteration
extract a row from an iteration - I need help writing this iteration - Messages
#1 Posted: 5/17/2023 11:23:59 AM
Orlando Suclupe Santamaria
0 likes in 11 posts.
I am learning how to use Smath Studio, I want to write an iteration where an increment of 0.5 is added to two declared variables "a" and "b" which are replaced in a formula and it gives me a final value "X" and the condition is that the iteration stops when the final value is equal to or less than a declared value "Y" to finally extract from the iteration array the row with the three values that meet this condition: [a b X]
I appreciate your help in advance, I am willing to donate
#2 Posted: 5/17/2023 1:25:27 PM
983 likes in 6866 posts.
Show your departure work, to be more helpful.
Iterate Demo.sm (47 KiB) downloaded 43 time(s).
#3 Posted: 5/17/2023 7:09:05 PM
This is the structure that I have been writing to iterate but I need to extract the row of interest, which in this example has to be less than or equal to sigma_adm_suelo, this row is the last
matrix_programming.sm (13 KiB) downloaded 45 time(s).
#4 Posted: 5/17/2023 7:46:44 PM
I already resolved it
matrix_programming.sm (13 KiB) downloaded 50 time(s).
#5 Posted: 5/18/2023 9:27:13 AM
⚜ Kenny Lemens, P.E. ᵂᴵ
74 likes in 164 posts.
Greetings,
You may want to consider the use of a for loop instead of a while statement:
Copy and Paste the following into your worksheet:
line(#,for(i:1,i<10,i:i+1,line(#,#,#,#,4,1)),#,3,1)
May this be of Good Help;
#6 Posted: 5/18/2023 10:20:07 AM
Greetings,
The result I am looking for is that it meets the initial condition, how would I stop at the iteration that meets this condition, to be able to do it using the "for" command that you suggested and not the 10 iterations that I declare for "i"
matrix_programming_for.sm (16 KiB) downloaded 46 time(s).
#7 Posted: 5/18/2023 12:01:52 PM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
992 likes in 1675 posts.
Hola Orlando. You can use break inside the for loop.
matrix_programming_for.sm (17 KiB) downloaded 51 time(s).
#8 Posted: 5/18/2023 12:05:01 PM
Greetings,
The 'i < 10' statement would be replaced with your criteria (ie., ≤ σ.adm_suelo). Regardless, the largest issue you have is with regards to how SMath programs; you need to follow the 'rules' of setting up programming functions within a line() group, where the last item is the value returned as a result.
Copy and paste the following into your worksheet:
C.summary:+line(C:matrix(max_rows:1,3),for(i:1,({1.075*(P.CM+P.CV)}/{B.zap_0*L.zap_0}-{6*(M.CMx+M.CVx)}/{B.zap_0*L.zap_0^2}+{6*(M.CMy+M.CVy)}/{L.zap_0*B.zap_0^2}≤σ.adm_suelo),i:i+1,line(el(C,i,1):B.zap_0,el(C,i,2):L.zap_0,el(C,i,3):{1.075*(P.CM+P.CV)}/{B.zap_0*L.zap_0}-{6*(M.CMx+M.CVx)}/{B.zap_0*L.zap_0^2}+{6*(M.CMy+M.CVy)}/{L.zap_0*B.zap_0^2},B.zap_0:B.zap_0-Δ,L.zap_0:L.zap_0-Δ,5,1)),C,3,1)
The matrix produced by C.Summary should be what you are after (I simplified the equ by removing Maxima() function calls)
#9 Posted: 5/18/2023 12:05:09 PM
Maxima is not popular in the Smath Community users.
Don't even recall a single of those decoration gyzmas.
matrix_programming (1) Ignore Maxima.sm (14 KiB) downloaded 50 time(s).
#10 Posted: 5/18/2023 12:57:44 PM
I have a problem, the power went out and now my file does not open. What can I do, does anyone know how to restore it?
ZAPATA_AISLADA.sm (154 KiB) downloaded 45 time(s).
#11 Posted: 5/18/2023 1:08:04 PM
1417 likes in 2873 posts.
Hello Orlando,
I'm sorry but the file is not recoverable (is filled with null characters).
#12 Posted: 5/19/2023 7:53:04 AM
Code the while loop from reconstruction.
#13 Posted: 5/19/2023 12:47:36 PM
ZAPATA_AISLADA - AVANCE.sm (143 KiB) downloaded 42 time(s).
Hello, I have already made progress with a new file, I used the "for" command and after extracting the first matrix with the values that meet the condition, I made the next iteration with another formula compare the first two columns and extract the matches next to the third column that has a different result, thanks for the help to all of you, I will continue posting new concerns and I will make my donation to smath studio
  • New Posts New Posts
  • No New Posts No New Posts
