1 Pages (10 items)
Ode solvers implementation - Messages
#2 Posted: 11/29/2018 11:48:00 PM
WroteI can't reproduce this in SMath.
1/1 in Smath 6179, proof: the snippet.
Cheers Alvaro
Integrate with ode solver.sm (29 KiB) downloaded 84 time(s).
#3 Posted: 11/29/2018 11:59:54 PM
You may not be able to implement the Mathcad bloc Given/ODEsolve.
ODEsolve is based on linterp. That is the first point.
The other point is that in Mathcad "linterp(x)" is a scalar function.
In Smath: ainterp, cinterp, linterp are simply interpolation fncts
They are not scalar functions. How does it reflects in ODEsolve ?
In Smath, ln(x), exp(x), ... are scalar from source code.
I tried to make cinterp scalar like in Mathcad, not to avail.
Please, persist on such a beautiful idea.
#4 Posted: 11/30/2018 1:16:48 AM
WroteI tried to make cinterp scalar like in Mathcad, not to avail.
This document was essentially designed to plot scalar the derivative on canvas,
as well as get a discrete export. Also included: the scalar quadratic.
Spline Deriv Infinitesimal.sm (70 KiB) downloaded 79 time(s).
#5 Posted: 11/30/2018 2:31:22 AM
Hi Jean. Actually not, just the solver, without the given.
I found how to call the odesolver, with D(x,y)=[f(x)].
This method is much more faster than the direct integration.
But remains the ln(0) error, which seems to be a bug in the odesolvers, because zero isn't in the domain range.
Integrate with ode solver.sm (10 KiB) downloaded 77 time(s).
Radovan Omorjan 11/30/2018 5:10:00 AM
#6 Posted: 11/30/2018 3:35:52 AM
The zero point is used to determine the dimension of the vector D(t,x) at runtime (D(0, x0)). The size of the system must be determined for the further operation of the numerical algorithm. It seems that it would be correct to substitute the beginning of the interval. I will try to change this. Also, if possible, I will support the one-dimensional case.
4 users liked this post
sergio 11/30/2018 5:43:00 AM, frapuano 11/30/2018 5:37:00 AM, Alvaro Diaz Falconi 11/30/2018 4:53:00 AM, Radovan Omorjan 11/30/2018 5:06:00 AM
#7 Posted: 11/30/2018 5:01:06 AM
Thanks Viacheslav. It's amazing the effort that you and the others plugins developers put in enhance SMath, with very spectacular results.
Вячеслав Мезенцев 12/3/2018 1:25:00 PM
#8 Posted: 11/30/2018 12:29:42 PM
WroteHi Jean. Actually not, just the solver, without the given.
Buenos dias Alvaro !
ln(0) was introduced in Mathcad 11 soon after release via update [from recollection]
There is more in the attached, specially wrt parametric D(,,,).
ODE 0_Model General.sm (29 KiB) downloaded 70 time(s).
#9 Posted: 11/30/2018 12:34:54 PM
#10 Posted: 11/30/2018 3:36:38 PM
... refreshed version wrt explore all solvers.
ODE 0_Model General.sm (38 KiB) downloaded 86 time(s).
Alvaro Diaz Falconi 11/30/2018 3:54:00 PM, frapuano 11/30/2018 5:58:00 PM, Davide Carpi 12/3/2018 9:18:00 PM
1 Pages (10 items)
New Posts
No New Posts
