Beta: SMath Studio 0.99.7803 (13 May 2021) - Messages
List of changes(between 0.99.7802 and 0.99.7803 versions)
Improvements
- Automatic update of the plug-ins on program start after installation of the new SMath Studio version implemented;
- Search Panel extended with the following options: Case sensitive, Whole word only, Exclude disabled, Exclude invisible;
- Text Region improved to support pasting Images/Regions from clipboard.
Corrections
- Critical issues happens on unexpected DoubleClickTime value provided by system fixed;
- Generating executables with SMath Viewer fixed.
Miscellaneous
- Text Region stability significantly improved;
- Logic of line height setting improved for Text Region;
- Mouse cursor mode corrected for Text Region on mouse move with Ctrl/Shift button pressed;
- Refactoring;
- Displaying of the progress improved in Splash screen;
- Interface translations updated.
Download
SMathStudioDesktop.0_99_7803.Mono.tar.gz (1 MiB) downloaded 688 time(s).
SMathStudioDesktop.0_99_7803.Setup.msi (2 MiB) downloaded 2145 time(s).
The file seems to work fine on the computer I created it on, but when I send it to another PC, windows defender blocks it and detects the trojan Win32/AgentTesla!ml.
Not sure how to handle this. I can't distribute exe files like this.
*when I send it in a zipped folder via email.
WroteI can't distribute exe files like this.
Any *.exe is prone to virus, though many are reputed safe.
IrfanView, WinGrab, WASP, ColorPick, Calipers ...
The MathSoft Collaboratory did reject any *.exe attachment.
WroteThe file seems to work fine on the computer I created it on, but when I send it to another PC, windows defender blocks it and detects the trojan Win32/AgentTesla!ml.
False positive. Anti-virus software sometimes do not like when programs creates other programs. You have to contact to your anti-virus vendor or exclude such programs from scanning.
Unfortunately I can do nothing with it.
I was using the native windows zip feature, maybe that had something to do with it?
Thanks for the quick feedback Andrey.
How are we supposed to share our exe files if they get blocked as viruses? I don't remember this being an issue before as I've sent several of my exe files before without issues.
WroteAlright, did some more testing and no matter how I send the file (removed extension, fake extension, zipped, file share download) windows is still detecting a virus.
I'm using Windows 10 and cannot reproduce this issue. Are you sure your PC has no viruses which could break exe files generated by SMath Studio?
By the way, the exact same exe file copied to to the other computer using a USB drive has no issues at all. Only having issues when the exe comes off of email or is downloaded.
WroteI'm using Windows 10 and cannot reproduce this issue. Are you sure your PC has no viruses which could break exe files generated by SMath Studio?
Probably he has one that machine doesn't aware of.
In my old job my pc has one too and all SMath Viewer files I produced with them had trojans.
At the same time that was not an issue with my home pc wtih same SMath version and files.
This issue has been corrected after a format.
https://online.drweb.com/
https://opentip.kaspersky.com/
Windows defender isn't a robust AV.
On the other hand, the SMath viewer files store the plugins necessary for their execution within the exe file. That is, if any of the extension files used by the .sm file that you "compile" has a virus, or a false positive report, it will only give that positive with the plugins you use in that particular file, which may be very difficult to reproduce that positive.
WroteOn the other hand, the SMath viewer files store the plugins necessary for their execution within the exe file. That is, if any of the extension files used by the .sm file that you "compile" has a virus, or a false positive report, it will only give that positive with the plugins you use in that particular file, which may be very difficult to reproduce that positive.
All plug-ins are compiled on the dedicated build machine (setup for SMath project exclusively) which has no Internet access and has installed Kasperski Anti-virus. In addition all files downloaded using HTTPS which guarantees compiled files are identical to what you received on your machine.
So what you've described is almost impossible situation.
WroteWroteOn the other hand, the SMath viewer files store the plugins necessary for their execution within the exe file. That is, if any of the extension files used by the .sm file that you "compile" has a virus, or a false positive report, it will only give that positive with the plugins you use in that particular file, which may be very difficult to reproduce that positive.
Hi Andrey. I'm explain very bad. Let me try to say the same with an example.
This file calculate a numerical value of an integral, but evaluated symbolically, only with SMath int(x^2,x,0,a) function. It's size is 2 793 bytes
SMathViewerWithOutMaple.zip (602 KiB) downloaded 58 time(s).
This other do the same, but with the maple plugin as maple(int(x^2,x,0,a)), and it's size is now 14 489 088 bytes.
SMathViewerWithMaple.zip (13 MiB) downloaded 58 time(s).
What I mean with "compile" it's that for this second file all the files for maple are stored in the exe file, for example gif.dll, mkernel.dll, cmaple.exe. Those maple files are very old, and are good candidates for false positives. It could be hard to determine for which plugin an AV like windows defender goes to return false positives if you don't know which plugin is stored in the exe SMath Viewer.
Hope now I explain better.
WroteProblems with copy and paste in document mode
Yeah, it is a known issue - copy/paste of content inside Text Region is not implemented yet (except simple text). I plan to handle it soon.
Thank you!
WroteDid a scan on the kaspersky site and the exe file is clean.
I have some good news regarding false positive detection! After a long night and morning I've found binary pattern which triggers some AVs to mark executables created by Viewer as malicious...
Knowing it I've added possibility to give AVs a fight! Unfortunately I have to disable compression of internal resources to do it, but I do not think it is so bad.
Please try a new SMath Studio version - it has the following checkbox (uncheck -> file size increased -> AVs are happy -> profit):
Here are results of testing the output result in VirusTotal:
Before
https://www.virustotal.com/gui/file/d1f299de59b684327e24cd600950e5339f7e2ebf3e65b0dc7fa71f82f384cb44/detection
After
https://www.virustotal.com/gui/file/d0e5782c2ea4793b426d9d39aed13e87d174dcda8bb2adb4823953893f835389/detection
Please confirm issue with copy/paste of exe files fixed now.
New Posts
No New Posts
