Fractal Tree
Fractal Tree - a programme for displaying a fractal tree - Messages
#1 Posted: 3/15/2020 2:48:37 PM
Gerard Bush
Gerard Bush
8 likes in 9 posts.
I have created a programme to display a fractal tree in a 2D plot.
fractal tree.sm (7 KiB) downloaded 75 time(s).
fractal tree.pdf (209 KiB) downloaded 80 time(s).
I would be interested to find out if there is a way to animate the plot process so that the fractal tree is drawn element by element, as each point is calculated.
Can anyone give me any pointers on how to do it?
If that is not possible, how would the animation be done after all the plot points are calculated?
Thank you
Gerard Bush
Davide Carpi 3/16/2020 12:19:00 PM
#2 Posted: 3/15/2020 6:30:25 PM
983 likes in 6866 posts.
Like this ... in ½ points.
fractal tree.sm (11 KiB) downloaded 70 time(s).
#3 Posted: 3/16/2020 7:13:02 AM
... hard to size the animation plot canvas.
Otherwise renders well ½ length ... greedy 1533 frames !
Search "Samples"... "Pattern" for lot more.
If you can't find and want more: please ask for.
Pattern fractal tree.sm (17 KiB) downloaded 59 time(s).
Gerard Bush 3/16/2020 8:25:00 AM, Davide Carpi 3/16/2020 12:19:00 PM
#4 Posted: 3/16/2020 8:16:56 AM
Gerard Bush
Gerard Bush
8 likes in 9 posts.
Thank you Jean,
That is just what I was looking for.
To reduce the number of points, and reduce the calculation time the minimum length can be increased. For example, change 'if lenght > 0.25' in the tree function to 'if length > 1.0'. I guess this could even be defined as a variable.
Cheers,
Gerard
Pattern fractal tree.sm (18 KiB) downloaded 59 time(s).
#5 Posted: 3/16/2020 9:04:22 AM
Fridel Selitsky
Fridel Selitsky
520 likes in 451 posts.
In the program Jean I added the growth of the tree
Pattern fractal 1.sm (12 KiB) downloaded 72 time(s).
5 users liked this post
Davide Carpi 3/16/2020 12:19:00 PM, Alvaro Diaz Falconi 3/17/2020 4:15:00 PM, Вячеслав Мезенцев 3/16/2020 1:59:00 PM, frapuano 3/16/2020 9:35:00 AM, Gerard Bush 3/16/2020 10:55:00 AM
#6 Posted: 3/16/2020 5:55:35 PM
Few more attached ... Search Julia, Mandelbrot in Forum.
Pattern Koch.sm (11 KiB) downloaded 60 time(s).
Pattern Frieze Heppi.sm (11 KiB) downloaded 62 time(s).
Pattern Hilbert.sm (8 KiB) downloaded 51 time(s).
Pattern Patch Work.sm (10 KiB) downloaded 65 time(s).
Pattern Fractal Sierpinski.sm (10 KiB) downloaded 56 time(s).
Pattern Snail.sm (26 KiB) downloaded 59 time(s).
Pattern Fern.sm (19 KiB) downloaded 60 time(s).
Pattern Sierpinski Kover.sm (16 KiB) downloaded 60 time(s).
Pattern Etoile Magic [Short].sm (46 KiB) downloaded 58 time(s).
Pattern Sierpinski Triangles.sm (35 KiB) downloaded 58 time(s).
Pattern Prototile.sm (116 KiB) downloaded 63 time(s).
#7 Posted: 3/16/2020 5:59:14 PM
Pattern PythagorasTree.sm (6 KiB) downloaded 71 time(s).
#8 Posted: 3/17/2020 3:24:27 PM
Hello Gerard ! ... today, I have cut the tree for You.
Pattern fractal tree [CUT].sm (11 KiB) downloaded 71 time(s).
Gerard Bush 3/18/2020 9:56:00 AM
#9 Posted: 3/18/2020 9:58:54 AM
Gerard Bush
Gerard Bush
8 likes in 9 posts.
Thank you very much, Jean and Ber7 for your additions!
#10 Posted: 3/18/2020 12:06:31 PM
Fridel Selitsky
Fridel Selitsky
Fractal tree with leaves
Pattern fractal 3.sm (12 KiB) downloaded 79 time(s).
Davide Carpi 3/18/2020 3:07:00 PM, Gerard Bush 3/18/2020 4:59:00 PM, NDTM Amarasekera 3/19/2020 6:03:00 AM
  • New Posts New Posts
  • No New Posts No New Posts
