Quaternion rotation
Quaternion rotation - Comments & Collaboration will help - Messages
#1 Posted: 8/22/2015 1:13:05 AM
983 likes in 6866 posts.
Lovely Breather, Wikipedia has deleted the original image from 10 years ago.
Mathcad 11 is unbeatable for Breather up to meshing 199.
Smath does very good job.
Just too bad I can't make a colored plot like the GNU plot Kuen surface.
Wht's the trick to make Maxima plot work ?
jmgiraud@bell.net
Rotate Breather [Quaternion].sm (50 KiB) downloaded 124 time(s).
#2 Posted: 8/22/2015 5:32:22 PM
1222 likes in 2150 posts.
Sometimes the Maxima function Solve can replace the Mathcad solution block, see attachment.
What is the problem with Maxima plotting? Please give an example of what you try and how it fails.
#3 Posted: 8/27/2015 12:08:05 PM
"Sometimes the Maxima function Solve can replace the Mathcad solution block, see attachment.
What is the problem with Maxima plotting? Please give an example of what you try and how it fails."
_________________________________
Thanks Martin,
I have remade Quaternion that will work independently of Maxima.
I'm puzzled reading the error message "forcibly" ?
Does it mean Andrey is no authorized to let Smath users to access Maxima ?
No way I could make Breather plot something like the 'Kuen' surface example.
You will understand all by reading the attached Smath WS.
Cheers, be good ... Jean
Rotate Breather [Quaternion].sm (311 KiB) downloaded 104 time(s).
#4 Posted: 8/30/2015 8:02:18 AM
As to the error message: Do you use the portable version with maxima? (with everything pre-installed). Closed connection may happen if maxima is crashed.
Maxima can access gnuplot 3d functions, for examples have a look at the handbook section 5.1.
I can't reproduce the Mathcad plots, there might be translation errors between smath and maxima, but it works for the example from the gnuplot homepage given in the handbook (Kuen's surface, the function does not include hyperbolic functions)
At least, the attached sheet gives a starting point.
rot.sm (426 KiB) downloaded 101 time(s).
  • New Posts New Posts
  • No New Posts No New Posts
