Insert unit Angle
Insert unit Angle - Messages
#1 Posted: 11/12/2017 12:50:22 PM
Magne Kristian Oen
Magne Kristian Oen
0 likes in 5 posts.
I am new user of Smath and in order to teach myself a bit about this software I am trying make a simple calculation in degrees. However, I cannot find degrees? I cannot find Angle in the insert meny at all? What am I doing wrong?
Best Regards, Magne
#2 Posted: 11/12/2017 1:18:16 PM
115 likes in 329 posts.
you can use
Insert -> Unit -> select "degree"
or shortcut ' -> select "°"
#3 Posted: 11/12/2017 1:21:08 PM
Magne Kristian Oen
Magne Kristian Oen
0 likes in 5 posts.
Sorry my question was inaccurate, degrees as 360 per whole circle not radians.
Thanks for the quick reply anyway!
Magne
#4 Posted: 11/12/2017 1:27:19 PM
Magne Kristian Oen
Magne Kristian Oen
0 likes in 5 posts.
Sorry my bad!
I misunderstood the callout, it IS ordinary degrees!
Thanks and regards, Magne
#5 Posted: 11/12/2017 3:03:03 PM
983 likes in 6866 posts.
2/3=38.1972°
#6 Posted: 11/12/2017 10:12:08 PM
#7 Posted: 11/13/2017 4:09:22 AM
Magne Kristian Oen
Magne Kristian Oen
0 likes in 5 posts.
Thank you!
This is exactly what I am unable to do! How do I make the trigonometric function return degrees?
Do I simply type the unit after the result? ( I am sorry if these questions are really daft!?)
Magne
#8 Posted: 11/13/2017 6:50:48 AM
All numerical functions are approximations in computing machinery.
Trigonometric function are in radian. If you want result in °
1. click on the empty place holder of the result,
2. click on the unit drop down menu from the tool bar,
3. click on ° or deg ... scroll down for 'rad' if you want result in radian.
SeaSpray 10/9/2018 5:25:00 PM
#9 Posted: 11/13/2017 7:35:20 AM
Magne Kristian Oen
Magne Kristian Oen
0 likes in 5 posts.
Thank you very much! Now I can make it work. I thought I had tried this but I probably used the input "position" wrong, I believe I simply typed it at the wrong place.
Thank you again, this is great forum!
Regards, Magne
  • New Posts New Posts
  • No New Posts No New Posts
