2D plot, parametric functions
2D plot, parametric functions - Combined with sys() matrices - Messages
#1 Posted: 10/11/2023 9:51:06 PM
554 likes in 1333 posts.
When a parametric function is stacked with sys() nested matrix or matrices, it doesn't plot.
It is plotting if they are at same level in sys(), plot1 example.
When there is no parametric function, there is no problem, plot3 example.
Otherwise 2D plot is not capable to execute.
XY-Plot has no issues at all.
plotbug.sm (23 KiB) downloaded 74 time(s).
UserPostedImage UserPostedImage UserPostedImage
Oscar Campo 10/11/2023 10:28:00 PM
#2 Posted: 10/14/2023 9:28:44 PM
1222 likes in 2150 posts.
Once in general the plot regions (built-in, X-Y Plot) can handle nested lists, it is fair to call the failure to do so in special cases a bug
#3 Posted: 10/15/2023 2:04:12 AM
983 likes in 6866 posts.
This freak can be doctored. However, a native bug.
Freak X_Y.sm (18 KiB) downloaded 57 time(s).
#4 Posted: 10/17/2023 2:46:49 PM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
992 likes in 1675 posts.
Another example where the bug described by overlord makes things more complicated as the SMath plot cannot handle nested lists
#5 Posted: 10/17/2023 3:14:22 PM
1402 likes in 1708 posts.
Parsing the input data is a rather difficult part of such components. A dedicated designer is needed to cover commonly used use cases while avoiding ambiguity.
Some of the examples shown here were not originally intended to be used, but are artifacts of a particular implementation. Increasing complexity of input variants requires careful testing of compatibility with old behavior. This is especially true for nested structures.
For X-Y Plot component, I chose some use cases that I indicated in the first post and, when updating, I constantly checked that the specified examples worked correctly.
Oscar Campo 10/17/2023 4:51:00 PM, Alvaro Diaz Falconi 10/18/2023 4:50:00 AM
  • New Posts New Posts
  • No New Posts No New Posts
