Two Overhang Beam with UDL
Two Overhang Beam with UDL - Moment diagram Problem - Messages
#1 Posted: 2/20/2023 11:33:13 AM
yoswos
yoswos
0 likes in 6 posts.
I have attached a mathcad file.. and the moment diagram at the end doesn't match
with expcted output.. it should have gone smoothly to end with x coordinate 5m.
but at certain point it has jumped to postive rigion.
Please help fix it.
Thanks
#2 Posted: 2/20/2023 5:05:51 PM
554 likes in 1333 posts.
I have no idea why mathcad plots that segment faulty.
But it is possible to plot correct graphic in SMath.
However SMath integration is not very good and fast.
It will take much more time than mathcad, and zig-zagy.
You can improve plot by increasing Integrate: Accuracy.
It is in Tools>Options>Calculation.
PS: I increased accuracy to 500 to get a decent plot.
It took 50 seconds to plot in the picture!!
Integration should really be improved.
UDL.sm (18 KiB) downloaded 60 time(s).
#3 Posted: 2/20/2023 6:14:20 PM
1222 likes in 2150 posts.
In the interactive handbook you can find examples for beam analysis.
They use symbolic integration and equation solving with Maxima. This is very fast, except for the Maxima restart at the beginning of the sheet (can be removed if all works well).
Show Spoiler
example maxima beam.sm (41 KiB) downloaded 58 time(s).
#4 Posted: 2/21/2023 2:35:40 AM
yoswos
yoswos
0 likes in 6 posts.
Sorry but I have problem again
with M(5m)=-0.2083 kN m
it should have been
M(5m)=0
#5 Posted: 2/21/2023 2:42:21 AM
yoswos
yoswos
0 likes in 6 posts.
it should have been
M(5m)=0
My sorry it is correct.. since it is overhang it should have moment at the end;;
#6 Posted: 2/21/2023 2:49:22 AM
Though it should be smaller. Probably zero by the way.
Result can be reduced with integral accuracy set to 10000.
SMath integral algorithms are not good enough.
#7 Posted: 2/21/2023 4:46:08 AM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
992 likes in 1675 posts.
Hi. Remembering that solving an ODE is also told to integrate it:
UDL.sm (22 KiB) downloaded 55 time(s).
The domain can also be restricted to M(x) by multiplying it by the corresponding inequalities.
Вячеслав Мезенцев 2/21/2023 7:54:00 AM, NDTM Amarasekera 2/21/2023 11:27:00 AM
#8 Posted: 2/21/2023 10:02:18 AM
983 likes in 6866 posts.
Finite Differences [FD] is a very good yardstick insensitive to noise.
It that what you mean moment at the end ?
Page2 FD.sm (57 KiB) downloaded 40 time(s).
#9 Posted: 2/21/2023 11:29:30 AM
This is a marvelous solution.
I learned a new thing today.
Thanks Razonar.
Maybe I am wrong but I think formula should be like this.
Huge kN*m values appear if calculated as in the picture above.
Alvaro Diaz Falconi 2/21/2023 2:49:00 PM
#10 Posted: 2/21/2023 12:55:20 PM
ODE integrator(s) range from exact [rarely]
approx. 4 decimals ... to glorious freak !
64 bits Smath does not have 32 bits Matlab ODE.
Recently checked on my PC2 this damned bug.
ODE 0 TEST [17].sm (45 KiB) downloaded 43 time(s).
Revisit from few months ago.
#11 Posted: 2/21/2023 2:51:56 PM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Huge kN*m values appear if calculated as in the picture above ...
Hi overlord. You're absolutely right. Thanks for catching that error. Only 3 orders of magnitude. Who could worry about that? The Mathcad block can also be used, although I don't know if this is the best way to deal with the units, using an intermediate function Mo.
UDL.sm (26 KiB) downloaded 51 time(s).
  • New Posts New Posts
  • No New Posts No New Posts
