.sm File corrupted with no error message
.sm File corrupted with no error message - Messages
#1 Posted: 5/15/2017 4:43:52 PM
sdfms
sdfms
0 likes in 3 posts.
I have done a calculation on a retaining wall, which suddenly has become corrupted. Smath will open the file, but won't display most of it. The last pages are missing, and there is just a red error dot on the last page (see pic)
Show Spoiler
Stottemur.sm (491 KiB) downloaded 91 time(s).. Is it somehow possible to restore this?
#2 Posted: 5/15/2017 5:14:58 PM
1230 likes in 2155 posts.
Here you are:
Stottemur_Kr.sm (491 KiB) downloaded 88 time(s).
#3 Posted: 5/15/2017 5:17:39 PM
sdfms
sdfms
0 likes in 3 posts.
That is amazing, thank you so much, you really saved me a lot of time there!
#4 Posted: 5/15/2017 5:50:11 PM
983 likes in 6866 posts.
Smath is capricious with some plugins. If an image region has not completed
[right or wrong], most likely Smath will not save and will file 0 kb. That
is because an image region is resident in the work sheet, therefore: if
not done nothing to save. In your document, you had an empty "Writer region"
in red. Delete it, bingo => your document is 100 % there.
#5 Posted: 5/16/2017 1:06:11 PM
sdfms
sdfms
0 likes in 3 posts.
Thanks for the explanation. Is there any way to easily find empty regions like that?
#6 Posted: 5/16/2017 3:11:45 PM
1418 likes in 2873 posts.
It is an issue solved with the latest beta version, so you can upgrade and simply open the file with that version; if you won't update to a beta version you can still use the beta just to to open and save the file, then open this file with your stable SS.
#7 Posted: 5/16/2017 8:34:31 PM
Is there any way to easily find empty regions like that ?
"empty region": you mean an unspecified/not filled region.
Up to now, I never noticed Smath sending some region anywhere
in the work sheet. Mathcad 11 would [once in a while] send
region [usually a dead region] pages'sss down, pages'sss right.
In Smath, past the last region, next page is blank [blue].
  • New Posts New Posts
  • No New Posts No New Posts
