Script Region
Script Region - Extends SMath Studio with a Script Region (c#, vb.net, python) - Сообщения
#41 Опубликовано: 16.09.2024 09:39:13
usamakhan
usamakhan
3 сообщений из 80 понравились пользователям.
To be exact, there is no thermodyamic library (coolprop, prode) available to linux version. Thus a more suitable option is this plugin instead of changing multiple others
#42 Опубликовано: 17.09.2024 19:18:12
You are on the spot, some plugins have no equivalent under linux.
I hope situation changes but have no optimism about it.
#43 Опубликовано: 24.11.2024 00:21:40
1 554 сообщений из 1 864 понравились пользователям.
As a temporary solution, I decided to add a function that can execute text scripts. Unfortunately, I can't build a working plugin on the server, so for now I'm just showing how it will work.
Oscar Campo 24.11.2024 16:48:00, Alvaro 25.11.2024 12:47:00
#44 Опубликовано: 17.12.2024 05:49:03
usamakhan
usamakhan
overlord, is there any way you have found to run python scripts under Smath Mono Linux?
