How to display string element of the matrix in Smath Viewer?
How to display string element of the matrix in Smath Viewer? - Сообщения
#21 Опубликовано: 14.03.2021 00:37:53
CBG
CBG
Hello wb.c
Hola Alvaro
I already reinstalled Smath Studio and the viewer still doesn't work for me.
The EXE file that wb.c publishes if it works for me, it would be interesting
to also have the SM file to be able to compile it to EXE, and check if it works.
Thanks a lot
Carlos
#22 Опубликовано: 14.03.2021 17:34:33
26 сообщений из 155 понравились пользователям.
Here it is.
99.7739.40423_Test.sm (2,51 КиБ) скачан 1088 раз(а).
#23 Опубликовано: 14.03.2021 23:54:35
CBG
CBG
Hello wb.c
Thank you very much for the file.
I compiled it to an EXE file and it worked perfectly fine.
I did a test again generating the file myself, and now everything works fine.
Thanks a lot
Carlos
#24 Опубликовано: 19.03.2021 12:14:54
Ruben Sidranski
Ruben Sidranski
Hello wb.c
Thanks a lot
Carlos
wb. c and Carlos,
I suggest posting this in the bugs log. The idea of the viewer is that the user would not need the file or to re-compile the EXE.
