1 страниц (11 вхождений)
Debugging help needed - Getting error message on variable in formula, but when printing separately the value is there - Сообщения
Trying first time with some bigger formula set, but now I have run into a problem with some error propagating into the calculation. Seems more or less lie anything becomes a problem some way down and even if I reformulate the formulas there pops up another problem with a value not being set as shown in the attachment. When I rewrote the formula then another value was marked red.
Feeling like the program is either running out of memory or there is a problem somewhere else causing the problem in the last part.
I saw someone else looking into the text file here on the forum and I see there are some error message there without me understanding how to debug it:
Hope someone have time to tell kick me in the right direction here
Terje
Terje
WroteHope someone have time to tell kick me in the right direction here
Attach the document [no monkey see, no monkey do].
Define the undefined or make the formula dependent of the parameters.
WroteAttach the document [no monkey see, no monkey do].
Jean is right.You want something that is very time consuming for other people to recreate the document they see on a screenshot and debug it while the document can be simply posted.
Thanks for answering, I didn't attache the file because I wasn't sure it was OK to do this in here.
Blandingers viskositet_R01.sm (272,29 КиБ) скачан 762 раз(а).Attached is the file.
Best Regards,
Terje
Best Regards,
Terje
As far as I can see I have defined the variable here:
Have I done something wrong in this definition?
When I try to print the variable other places in the document it seems like it is defined since it returns a value of zero (which it should have).
Did a test with different value
and it still is a problem even if the value is defined:
Appreciate all help from you here!
Terje
Terje
Thanks Alvaro and the rest for assisting me here! Finally found the error with your help now.
I see you use an Unknowns() function, is there some documentation of that one? Did not get same result as you when I tried to enter it.
Terje
Terje
