Array of circles
Array of circles - Сообщения
#1 Опубликовано: 04.10.2021 08:36:07
RAJED MAGLINTE
RAJED MAGLINTE
Good day!
I'm trying to generate an array of circles but it looks like I am missing something. The data I have come up with won't plot.
Thank you in advance for any help.bolt array.sm (13,33 КиБ) скачан 628 раз(а).
#2 Опубликовано: 04.10.2021 08:48:10
fedeghi
fedeghi
25 сообщений из 112 понравились пользователям.
In case of multiple traces, plot expects a system of data as input.
It is sufficient to convert the "boltplot" big matrix into a system (containing one matrix for each circle).
Command mat2sys()1 will do the work.
See attachment
Bye
bolt array.sm (17,74 КиБ) скачан 640 раз(а).
#3 Опубликовано: 04.10.2021 09:49:39
From there, you can manage all sorts of:
number of bolts in any radii.
Page11 Bolt Circle.sm (13,6 КиБ) скачан 736 раз(а).
#4 Опубликовано: 04.10.2021 10:52:02
This one is Fourier style for elliptical bolt circle.
Page13 Bolt Cicle Fourier.sm (12,03 КиБ) скачан 661 раз(а).
#5 Опубликовано: 04.10.2021 10:55:16
579 сообщений из 1 348 понравились пользователям.
fedeghi has the correct answer.
multiple plots needs to be in sys(), not matrix.
I don't know the purpose of replies after that, as usual..
#6 Опубликовано: 04.10.2021 11:10:06
... as usual for larger prospective insight.
Page13 Bolt Cicle Fourier Otherwise.sm (20,87 КиБ) скачан 692 раз(а).
#7 Опубликовано: 04.10.2021 11:14:25
or you can just keep within the question.
and don't throw every filename match to topics.
#8 Опубликовано: 04.10.2021 12:07:20
... more concentric/shifted
bolt array ... visit TEMA standard.
Circle Map.sm (12,35 КиБ) скачан 589 раз(а).
#9 Опубликовано: 04.10.2021 21:45:35
RAJED MAGLINTE
RAJED MAGLINTE
Thanks everyone. Really appreciate your help.
#10 Опубликовано: 05.10.2021 05:06:02
1 303 сообщений из 2 218 понравились пользователям.
You also could use circular symbols (top row: built-in plot region, 2nd row: XY-Plot region.
However, these won't scale when zooming the plot.
In XY-Plot, you also could use geometric objects, which scale as expected.
bolt array_Kr.sm (11,41 КиБ) скачан 613 раз(а).
