Script Region
Script Region - Extends SMath Studio with a Script Region (c#, vb.net, python) - Messaggi
#21 Pubblicato: 18/07/2018 14:46:46
1.558 apprezzamenti in 1.868 post.
Gruppo: Moderator
Updated. System.Diagnostics namespace added.
Script.Process.sm (4,45 KiB) scaricato 1793 volta(e).
@echo off
echo Hello
exit
Mostra spoiler
frapuano 18/07/2018 17:17:00
#22 Pubblicato: 15/08/2018 01:53:00
KhasanMamaev
KhasanMamaev
3 apprezzamenti in 5 post.
Вячеслав благодарю за Скрипт регион. Этот инструмент делает возможности СМат Студии практически безграничными. Немного программирую на Python. Я так понимаю, что в Script Region используется
IronPython?
#23 Pubblicato: 15/08/2018 04:32:44
Gruppo: Moderator
Да, используется IronPython.
#24 Pubblicato: 17/09/2018 00:22:21
Gruppo: Moderator
Updated.
- input placeholder removed;
- terms variable removed;
- SMath.Controls assembly added.
#25 Pubblicato: 18/09/2018 10:26:21
Gruppo: Moderator
Updated. Version 0.2.x.x.
Changes:
- xml serialization format changed;
- reworked.
Old versions of the plugin will not be able to open files of a new format.
You can change font with mouse wheel and Control key when region selected.
Disabled until the better implementation.
#26 Pubblicato: 10/10/2018 17:36:37
Farja
Farja
1 apprezzamenti in 7 post.
With the last changes in the plugin, this simple script to get the filename of the current worksheet stop working:
store.AddDefinition( terms[0].Text, new Term[0], new Entry( "\"" + store.FileName + "\"" ) );
The original question, and the script to get the filename its from this post:
https://en.smath.info/forum/yaf_postsm39408_MathcadFileAccess.aspx#post39408
Thanks for your help!
#27 Pubblicato: 11/10/2018 03:54:40
Gruppo: Moderator
#28 Pubblicato: 12/10/2018 12:35:58
Farja
Farja
Thanks Uni! That change did the trick
#29 Pubblicato: 14/11/2019 02:04:35
KhasanMamaev
KhasanMamaev
I want to show you a video about the operation of the Script Region plugin
#30 Pubblicato: 04/03/2021 18:56:16
26 apprezzamenti in 155 post.
What happened to this plugin? Seems like it had a lot of potential.
#31 Pubblicato: 05/03/2021 01:03:05
Gruppo: Moderator
I don't have time to finalize his code editor. Now it is inconvenient to use it.
#32 Pubblicato: 08/03/2021 08:54:24
João Felipe Seráfico Melo
7 apprezzamenti in 62 post.
Hi, uni!
I'm wondering if the script region for VB would allow me to access a COM engine.
I'm trying to use Autodesk Robot via SMath thorugh its API.
Is there any chance of success in this endeavour?
A simple example of what I've got:
Imports System
Imports RobotOM
Module Program
Sub Main()
Dim robapp As IRobotApplication
robapp = New RobotApplication
robapp.Project.CalcEngine.Calculate()
robapp.Project.Close()
robapp = Nothing
End Sub
End Module
#33 Pubblicato: 08/03/2021 09:11:50
Gruppo: Moderator
As far as I know, there are theoretically no restrictions of any kind. But practically in the plugin code the list of used libraries is strictly specified. In order to use COM-objects, the text of the program is not enough. It is necessary to make it clear to the linker what this program is composed of. Therefore, it will definitely not work now, since even the import directive is not supported.
I can expand the script format like Jon Skeet did. I didn't find an example, but he suggested splitting the code into two parts: a header and a script. Three dots are used as a separator. The header consists of an import list. This list can be used to partially restore dependencies.
In general, it is possible to modify the plugin to do this kind of thing. But I have my own job and it is difficult for me to make significant changes in the existing code.
#34 Pubblicato: 08/03/2021 15:33:46
Thanks for your reply, uni
I totally understand. I'll probably need to use the API via Excel then.
#35 Pubblicato: 16/11/2022 11:30:04
Camilo
Camilo
2 apprezzamenti in 1 post.
This plugin cant be installed on the latest version of Smath:
Вячеслав Мезенцев 16/11/2022 12:53:00, Thiago Pereira 30/11/2022 11:43:00
#36 Pubblicato: 30/11/2022 11:46:58
Thiago Pereira
Thiago Pereira
0 apprezzamenti in 5 post.
Same as Camilo. Error to/ or update/ reinstall plugin.
#37 Pubblicato: 02/12/2022 05:06:36
Gruppo: Moderator
The problem appeared, but its cause is not yet clear. I'll let you know when it's resolved.
#38 Pubblicato: 02/12/2022 13:41:05
⚜ Kenny Lemens, P.E. ᵂᴵ
85 apprezzamenti in 181 post.
Viacheslav,
I was developing an plugin between v1.0 and v0.99 and while my plugin 'worked,' I noticed my region interfered with the graphics (local version, in debug mode), that is the graphics fail to print (and sometimes load) when the region was processed/drawn. I had to reference the version specific *.dlls and that solved my problem. As such, I also noticed that some of the properties/classes changed ever so slightly (not enough to fail a compile, but enough to interfere with operations).
I didn't document this in detail though. I'm just wondering if you have some elements tied to the v0.99- that the v1.00+ no longer implements.
This is an amazing tool; thank you for developing it and I hope you are able to restore its functionality!
-Kenny Lemens, P.E. ᵂᴵ
#39 Pubblicato: 15/09/2024 02:40:31
usamakhan
usamakhan
7 apprezzamenti in 97 post.
Is there any plan to implement this plugin in Linux? For instance I have some chemical engineering python libraries & during calculation data exchange between SMath & terminal will be of great value.
#40 Pubblicato: 16/09/2024 01:30:39
Gruppo: Moderator
I need to rewrite the code editor, the problem is in its use or I need to replace it with another one. This is a complex job requiring great attention to detail.
Using the built-in programming language in the document has not been needed by many people yet. I postponed the implementation until better times.
Oscar Campo 18/09/2024 22:49:00
