Imperial Units
Imperial Units - Messaggi
#21 Pubblicato: 15/04/2021 11:39:23
26 apprezzamenti in 155 post.
Check the \AppData\Roaming\Smath Folder, it seems to have extensions and user setting in it. As far as I know, everything can be moved to the main install folder containing the exe. However, every you open Smath, a new folder will be created in this Roaming folder containing a setting file.
When you run the portable version, it will create this settings file in the main folder for the portable version containing the exe.
#22 Pubblicato: 15/04/2021 12:16:38
Jason McCool
Jason McCool
9 apprezzamenti in 78 post.
Good to know. I thought there was another folder with program-related stuff that I'd come across before; I always forget about that Roaming directory.
Thanks!
Jason
