Graph animation
Graph animation - Messaggi
#21 Pubblicato: 30/12/2012 10:06:59
Fridel Selitsky
Fridel Selitsky
520 apprezzamenti in 451 post.
2013
Happy.sm (7,95 KiB) scaricato 1401 volta(e).
Andrey Ivashov 03/01/2013 10:00:00, Davide Carpi 30/12/2012 10:12:00
#22 Pubblicato: 16/02/2013 04:24:34
Fridel Selitsky
Fridel Selitsky
optical illusion
The idea is taken from the site
http://www.mapleprimes.com/maplesoftblog/35171-Its-Better-With-Maple
Although the vertical distance between the curves is constant,
it seems that with increasing distance from the axis of Y, they are getting closer.
Animation helps to overcome this optical illusion
Illusion.sm (5,04 KiB) scaricato 1426 volta(e).
Davide Carpi 16/02/2013 07:42:00
#23 Pubblicato: 24/02/2013 12:04:26
Fridel Selitsky
Fridel Selitsky
Rolling disk on a parabola
ParCyc.smz (4,79 KiB) scaricato 1505 volta(e).
Davide Carpi 24/02/2013 14:36:00
#24 Pubblicato: 02/03/2013 01:16:50
Fridel Selitsky
Fridel Selitsky
Bullseye Illusion
The idea is taken from the site:
[url]: http://demonstrations.wolfram.com/BullseyeIllusion/[/url]
Although the white region has the same area as the blue ring, it appears to be larger
Bullseye.smz (2,92 KiB) scaricato 1506 volta(e).
ioan92 28/07/2013 16:27:00, Davide Carpi 02/03/2013 14:23:00
#25 Pubblicato: 28/07/2013 14:41:20
Fridel Selitsky
Fridel Selitsky
Animation examples from the book “Introduction to Statics and Dynamics
by Rudra Pratap, Andy Ruina.Publisher: Cornell University 2009”
http://archive.org/download/ost-engineering-ruinapratap8-21-10/RuinaPratap8-21-10.pdf
Planar motion1.smz (74,44 KiB) scaricato 1553 volta(e).
Davide Carpi 28/07/2013 15:51:00, ioan92 28/07/2013 16:27:00
#26 Pubblicato: 12/09/2013 14:13:27
Fridel Selitsky
Fridel Selitsky
Three Dissections by Leonardo da Vinci
http://demonstrations.wolfram.com/ThreeDissectionsByLeonardoDaVinci/
Leo2.smz (5,61 KiB) scaricato 1440 volta(e).
Martin Kraska 12/09/2013 15:58:00, Davide Carpi 16/09/2013 08:48:00
#27 Pubblicato: 16/09/2013 08:46:53
kilele
kilele
134 apprezzamenti in 397 post.
Challenge for Ber7 :d
This would be a great SMath animation : Heatherwick's Rolling Bridge
See it in action on this video at 1 minute and 25 seconds :
?t=1m25s
Fridel Selitsky 16/09/2013 13:22:00, Davide Carpi 16/09/2013 13:37:00
#28 Pubblicato: 16/09/2013 13:22:27
Fridel Selitsky
Fridel Selitsky
Thank you for the wonderful example .
I'll try to implement it.
#29 Pubblicato: 19/09/2013 00:54:23
Fridel Selitsky
Fridel Selitsky
The Rolling Bridge
Bridge.smz (636,87 KiB) scaricato 1611 volta(e).
Davide Carpi 19/09/2013 00:56:00, Вячеслав Мезенцев 19/09/2013 11:22:00, ioan92 25/09/2013 17:13:00
#30 Pubblicato: 25/09/2013 16:42:16
lrcvs
lrcvs
3 apprezzamenti in 2 post.
Nice, Rolling Bridge!
See you this:
The author
Davide Carpi 25/09/2013 17:52:00, Fridel Selitsky 25/09/2013 18:35:00
#31 Pubblicato: 03/10/2013 03:55:36
Fridel Selitsky
Fridel Selitsky
http://ruina.tam.cornell...k/RuinaPratap8-21-10.pdf
A spring-mass system in space
A spring-mass system consists of two masses, m1 = 10 kg and m2 = 1 kg,
and a weak spring with stiffness k = 1N/m. The spring has zero relaxed
length.The system is in 3-D space where there is no gravity. Track the
motion of the system for the next 20 seconds. Plot the trajectory of
the two masses in space. The 3-D animation showing the trajectory of the
two masses obtained from the numerical solution . From the plot, it seems
like the smaller mass goes around the bigger mass as the bigger mass moves on its trajectory.
springMass4smz.smz (5,49 KiB) scaricato 1489 volta(e).
Davide Carpi 03/10/2013 05:39:00
#32 Pubblicato: 03/10/2013 05:32:30
Brian Runagle
Brian Runagle
13 apprezzamenti in 27 post.
Nice one Ber7!
archive.org had a problem with the link. The book can be found here:
http://ruina.tam.cornell.edu/Book/RuinaPratap8-21-10.pdf
Brian
#33 Pubblicato: 03/10/2013 06:37:02
Fridel Selitsky
Fridel Selitsky
Thank you very much, corrected.
Davide Carpi 03/10/2013 08:13:00
#34 Pubblicato: 21/04/2018 14:34:39
Fridel Selitsky
Fridel Selitsky
Animation of NPlot and 3d Plot graphs
The program is designed for graphs that do not have a built-in
animation capabilities
3dplot mk.sm (8,5 KiB) scaricato 1288 volta(e).
NplotAnimation.sm (14,61 KiB) scaricato 1318 volta(e).
frapuano 23/04/2018 03:02:00
