Improving Calculation Accuracy
Improving Calculation Accuracy - Determining the zeros of an equation using "solve" function and using Newton's method - Messaggi
#21 Pubblicato: 03/09/2022 13:06:14
... few more things in this project:
1. roots & Golden ratio in plot.
2. integration/derivative.
Nikolai roots.sm (116,28 KiB) scaricato 1288 volta(e).
#22 Pubblicato: 05/09/2022 03:14:40
Nikolay
Nikolay
0 apprezzamenti in 8 post.
Hello Jean Giraud,
Thanks again for your attention to my questions.
Could you help me with one more question?
Why can't I calculate in the file "Nikolai roots.sm"?
Clicking the "Recalculate page" button gives the error "F() - function isn't defined.".
Is this a problem in different versions of the program or a problem in another?
#23 Pubblicato: 05/09/2022 10:31:51
Total and impressive disaster !
Possibly, your Smath installation is defective ?
Possibly, your Smath version is kaput ?
On that last point, Designers can confirm.
I will make a PDF, so you will be able to code/sanity.
#24 Pubblicato: 06/09/2022 08:06:23
... run that test version. At worst, code as given.
You can'y escape eval(x*Bessel(1,x)-1.01*Bessel(0,x))
Nikolai roots Test.sm (14,75 KiB) scaricato 1298 volta(e).
Nikolay 06/09/2022 10:54:00
