noob question
noob question - How to get intermediate formula - Messaggi
#21 Pubblicato: 11/07/2022 14:29:59
Nicolae Olaru
Nicolae Olaru
1 apprezzamenti in 115 post.
Greetings Jean Giraud. I mean by "analytic", to write a function "func (arg)" using strictly the functions defined in smath (other than "Clear (arg)") whose result is identical to that provided by the predefined function in smath "Clear (arg)"
#22 Pubblicato: 11/07/2022 17:53:36
Analytical function(s) are function(s) that you can:
derive, integrate, Laplace, Fourier, else transform ... etc.
Clear(▪,▪,▪, ...) simply evaporates the collection.
What you can do: front end a program by Clear(▪,▪,▪, ...)
If your program is analytical, de-facto Clear is analytical,
that is for twisted mind... glass ½ full/empty.
#23 Pubblicato: 12/07/2022 10:49:30
Once the vector 'x' has been cleared ▼ internally
'x' is free for analytic/numeric function(s)...
If that's what you mean by analytic Clear(,)
If you have comments or more in mind ... welcome.
Maths Clear.sm (22,25 KiB) scaricato 1320 volta(e).
#24 Pubblicato: 13/07/2022 17:04:50
Nicolae Olaru
Nicolae Olaru
... Clear(▪,▪,▪, ...) simply evaporates the collection ...
OK. Then why doesn't this function exist in MathCAD - at least until MathCAD 14, which I use. In fact, that would be the basic idea. How do I synthesize such a function in MathCAD, a function that I often miss ?!
#25 Pubblicato: 14/07/2022 11:08:06
Mathcad 14 was a freak. Saved as 11 ... back 11 was Christmas decoration !
At Mathsoft home, my MCD 11 crashed Mona MCD 14.
Mathcad 11 was a semi-compiled CAS, much different than Smath Plugins.
In Mathcad 11 and earlier, variables, data don't reside, nothing to Clear.
If 'x' has been ranged above and next you want the symbolic wrt 'x'
x:= ▪
it shows the place holder, then evaporated, free for symbolic.
Don't hesitate for more ... Jean.
#26 Pubblicato: 20/07/2022 05:49:08
Nicolae Olaru
Nicolae Olaru
OK. Many thanks Jean Giraud
#27 Pubblicato: 27/02/2023 19:23:16
⚜ Kenny Lemens, P.E. ᵂᴵ
85 apprezzamenti in 181 post.
Greetings,
Another solution was just posted as a worksheet example, located here: https://en.smath.com/forum/yaf_postsm80591_Showing-substitutions-in-a-formula.aspx#post80591
Mostra spoiler
As an additional observation to this whole topic, I achieved sufficient success if I did the following (without the need for a plugin or special functions):
  1. defining the equations before declaring any of the variables
  2. defining the variables and display evaluation immediately (optimization=NONE)
  3. display the equation, define optimization=NONE
  4. Final: display the equation, define optimization=numeric
Depending on your circumstance, utilizing Symbolic evaluation and calling the function Eval() may be in your best interest.
Hope this helps;
Alvaro 27/02/2023 21:47:00, Mark R Harris 28/02/2023 05:13:00
