Text Region Utilities
Text Region Utilities - Helps to set some Text Region properties - Messaggi
#41 Pubblicato: 03/11/2022 20:54:35
I can get links to files to work in Writer region, but being able to auto generate would be great. I can't quite figure it out.
auto generate ... you mean click on an ordinary text region
to convert in Writer Region and open the WR ribbon.
There is one more option you may need from Settings.
... the Wrap option(s) custom/page.
Custom delivers the stretch RHS handle.
Superb for inserting math region(s) in the WR.
In few clicks, you can offer an abstract publishing style.
No matter the size/color of an ordinary text region,
paste in WR ... default Arial ... then Settings.
#42 Pubblicato: 04/11/2022 05:37:22
Gruppo: Moderator
Is this plugin expected to work with 8253?
I'll check it, thank you.
#43 Pubblicato: 04/11/2022 10:28:37
That's what I meant ... 3 clicks:
1 ► WR ... 2 ► Settings [Ribbon] ... 3 ► Wrap Custom [RHS Handle]
#44 Pubblicato: 04/11/2022 11:13:39
Gruppo: Moderator
That is absolutely not what he meant.
Mark R Harris 05/11/2022 17:29:00, Oscar Campo 04/11/2022 13:47:00
#45 Pubblicato: 22/10/2025 13:18:07
Денис
Денис
0 apprezzamenti in 1 post.
adding a new link to a worksheet doesn`t work (neither a new text), following message is issued:
What could be a reason?
#46 Pubblicato: 23/10/2025 11:14:17
Gruppo: Moderator
SMath API has changed and I wasn't able to find a way to restore this feature.
Modificato 23/10/2025 12:00:30
