Using Data Tables
Using Data Tables - Best way to use Tables - Messaggi
#21 Pubblicato: 18/12/2014 04:42:27
seandale
seandale
0 apprezzamenti in 1 post.
The technology behind LayoutEngine (used for layout on your pages) is made up of Rows and Columns. Conveniently enough, so are tables. So, if you're talking about a simple data table, you could create it using text blocks and not need to code anything.Now, if you're talking about some huge, complicated table coding it in a Code Block would be better. Either way, it's an idea worth considering.As for me, I am testing the related data matrix generator of .net applications these days. Do you have any ideas about it? Or any good suggestion? I am totally a green hand on data matrix. Any suggestion will be appreciated. Thanks in advance.
