Custom Glyphs plugin (previously known as Functions' Extension)
Custom Glyphs plugin (previously known as Functions' Extension) - Messaggi
#21 Pubblicato: 27/05/2014 13:28:14
Gruppo: Moderator
PLUGIN UPDATED
- SS-83: custom skins for Maxima wrappers
The skin is applied to any Maxima(#) function (regardless the number of arguments)
As mentioned in the BTS, if is in Kay's plans (and there aren't bugs/things to change) he can copy the IPluginRegionDrawing code inside the Maxima MainClass.cs to have this feature embedded in the plugin.
Best regards,
Davide
sergio 03/03/2016 15:32:00, Martin Kraska 27/05/2014 15:19:00, Radovan Omorjan 27/05/2014 15:18:00
#22 Pubblicato: 27/05/2014 15:45:11
Gruppo: Moderator
Really nice, Davide. Thanks a lot.
I see two potential improvements with the size control of the outer parens
- They are a bit big for single line arguments
- They are a bit small for large expressions (smaller than the next inner level)
For outsiders it might be a bit difficult to find out what the symbol means and how to input it, but inside SMath you can inspect the help string by typing F12 when the function is marked. Would be fine to have the symbol on a side panel palette.
#23 Pubblicato: 27/05/2014 19:35:21
Gruppo: Moderator
You're welcome. I've made a change about the brackets following your suggestions (plugin updated)
This is a problem for any "dressed function" as you know (here range(#) is on the top of the hits).
AFAIK toolbars/palettes are hardcoded in SMath, so actually we can only ask in the BTS if is possible to unlock these features.
#24 Pubblicato: 06/06/2014 11:03:51
127 apprezzamenti in 342 post.
Ciao Davide,
I have a problem with the function 'cases' if used within the definition of a function that expects as a result numbers or strings.
[albumimg]353[/albumimg]
#25 Pubblicato: 06/06/2014 13:38:02
Gruppo: Moderator
cases() can only handle results that can be multiplied, as the function is expanded into a sum of the possible results multiplied by individual boolean statements, resulting in 0 or 1. Unless Andrey allows multiplication of strings (which could be very useful, at least multiplication by integers) or unless Davide changes the implementation of cases(), you are limited to numbers, matrices, lists and the like.
You can, however, wrap your strings into matrices and extract the element afterwards. That is not really a good solution, because outsiders won't comprehend the role of the index. Last not least this is also due to that one cannot tell the matrix brackets from ordinary algebraic ones
Edit: The above said applies only to numeric evaluation of the result. The solution is much easier, just switch the result optimization to "symbolic". This works no matter how the optimization setting of the definition is made.
sergio 06/06/2014 16:14:00
#26 Pubblicato: 06/06/2014 13:56:58
Gruppo: Moderator
Ciao Sergio
switch the optimization of the [math eng]s.c(z)[/math] definition to "numeric" or "none". This uses a nested if/else structure instead of the symbolic sum (available just if you define your function as "symbolic"; this is shown also in the first post attachment).
In wide worksheets you can check fastly the definition optimization calling an evaluation using "none" as optimization:
- if you see the sum with booleans, you have defined the function as symbolic;
- if you see the cases function, you have defined the function as numeric/none.
best regards,
Davide
#27 Pubblicato: 06/06/2014 16:26:55
thanks Davide and Martin,
in fact I often do not pay attention to this option (symbolic-numeric). It would be useful to be able to visually differentiate this aspect
#28 Pubblicato: 06/06/2014 18:21:08
Gruppo: Moderator
Yes, absolutely. You might consider voting for BTS issue SS-19.
#29 Pubblicato: 26/02/2015 19:59:33
Gruppo: Moderator
Hello Ioan
I'm unsure on what is happening here, moving the cases outside the function it works correctly
Whatever is the problem, seems that eval() helps to bypass the issue :d
ioan92 27/02/2015 10:59:00
#30 Pubblicato: 16/05/2015 04:53:29
madan26
madan26
0 apprezzamenti in 2 post.
exec1
exec2
I have solved this equation in sage math. Please guide me how to solve this equation in smath.
#31 Pubblicato: 16/05/2015 05:57:00
Gruppo: Moderator
You can try using solve
Here an example based on your function (stripped off some decimals, just to make the example)
P.S. if your question is not related with a plugin in particular, the next time please open the question in a new thread in the Questions section
#32 Pubblicato: 03/03/2016 15:04:47
Ernesto
Ernesto
13 apprezzamenti in 74 post.
How do you add lines to the cases function? I have just been copying the cases function from the example file in this thread, but those only have up to 4 lines. I need more lines for a problem I am working on.
#33 Pubblicato: 03/03/2016 15:16:12
Gruppo: Moderator
PLUGIN UPDATED SMath Studio 0.97.5737 and later
- Project name changed;
Since this relase, this plugin will be used only to add glyphs to existing functions in third party packages (such as Maxima) or not yet implemented functions. Real functions (at, ternary booleans, cases, Kronecker, perc, permil) will be moved in the Custom Functions plugin. I think this is better in terms of organization of the plugins and less cucumbersome to understand from the user why some functions are in a plugin instead of another.
I'm trying to make the transition as smooth as possible (even if this was a beta plugin with much less downloads of the Custom Functions), thus all functions are still included in this plugin but hidden (no dynamic assistance, no glyphs, no more documented here)
ioan92 03/03/2016 15:22:00
#34 Pubblicato: 03/08/2025 20:28:04
Gruppo: Moderator
I'd propose two custom glyphs:
The Macaulay bracket and the Mathcad column operator. The column operator has been requested elsewhere, I just put it here in the right thread.
It would be nice to reproduce these formulas directly in SMath.
Currently, it is already quite close but having it in the familiar way would be better.
QM-Linie.sm (128,43 KiB) scaricato 1510 volta(e).
ioan92 03/08/2025 20:57:51, Alvaro 03/08/2025 22:35:30
#35 Pubblicato: 04/08/2025 22:44:05
Gruppo: Moderator
They're both feasible as working functions (thus they would be part of Custom Functions in that case).
Maybe a custom col() could be made to accept negative arguments (f.e. -1 to extract the last column).
Modificato 05/08/2025 06:11:13
#36 Pubblicato: 23/08/2025 13:11:35
Oscar Campo
Oscar Campo
135 apprezzamenti in 309 post.
Gruppo: Moderator
The Macaulay bracket and the Mathcad column operator. The column operator has been requested elsewhere, I just put it here in the right thread...
I use this function :
Is useful to model beams on this way:
Please, see the attached file
QVM.sm (23,19 KiB) scaricato 1350 volta(e).
ioan92 24/08/2025 07:56:27
