Graph animation - Mensajes
optical illusion
The idea is taken from the site
http://www.mapleprimes.com/maplesoftblog/35171-Its-Better-With-Maple
Although the vertical distance between the curves is constant,
it seems that with increasing distance from the axis of Y, they are getting closer.
Animation helps to overcome this optical illusion
Illusion.sm (5,04 KiB) descargado 1421 vez(es).
Davide Carpi 16/2/2013 7:42:00
Bullseye Illusion
The idea is taken from the site:
[url]: http://demonstrations.wolfram.com/BullseyeIllusion/[/url]
Although the white region has the same area as the blue ring, it appears to be larger
Bullseye.smz (2,92 KiB) descargado 1490 vez(es).
Animation examples from the book “Introduction to Statics and Dynamics
by Rudra Pratap, Andy Ruina.Publisher: Cornell University 2009”
http://archive.org/download/ost-engineering-ruinapratap8-21-10/RuinaPratap8-21-10.pdf
Planar motion1.smz (74,44 KiB) descargado 1539 vez(es).
Three Dissections by Leonardo da Vinci
http://demonstrations.wolfram.com/ThreeDissectionsByLeonardoDaVinci/
Leo2.smz (5,61 KiB) descargado 1429 vez(es).
Challenge for Ber7 :d
This would be a great SMath animation : Heatherwick's Rolling Bridge
See it in action on this video at 1 minute and 25 seconds :
?t=1m25s
?t=1m25s
Thank you for the wonderful example .
I'll try to implement it.
Davide Carpi 16/9/2013 13:37:00
Nice, Rolling Bridge!
See you this:
The author
See you this:
The author
http://ruina.tam.cornell...k/RuinaPratap8-21-10.pdf
A spring-mass system in space
A spring-mass system consists of two masses, m1 = 10 kg and m2 = 1 kg,
and a weak spring with stiffness k = 1N/m. The spring has zero relaxed
length.The system is in 3-D space where there is no gravity. Track the
motion of the system for the next 20 seconds. Plot the trajectory of
the two masses in space. The 3-D animation showing the trajectory of the
two masses obtained from the numerical solution . From the plot, it seems
like the smaller mass goes around the bigger mass as the bigger mass moves on its trajectory.
springMass4smz.smz (5,49 KiB) descargado 1473 vez(es).
Davide Carpi 3/10/2013 5:39:00
Nice one Ber7!
archive.org had a problem with the link. The book can be found here:
http://ruina.tam.cornell.edu/Book/RuinaPratap8-21-10.pdf
Brian
Brian
Animation of NPlot and 3d Plot graphs
The program is designed for graphs that do not have a built-in
animation capabilities
3dplot mk.sm (8,5 KiB) descargado 1279 vez(es).
NplotAnimation.sm (14,61 KiB) descargado 1314 vez(es).
frapuano 23/4/2018 3:02:00
