[2d Plot] Axis limits
[2d Plot] Axis limits - Plots do not fit axes to data, so data are not visible. - Mensajes
#21 Publicado: 19/1/2019 14:01:05
justhumm
justhumm
0 me gusta en 18 mensajes.
X_Y plot => you set the x, y limits
the QuickPlot => you wheel/mouse/zoom the x, y
Shift wheel mouse for the x
Ctrl wheel mouse for the y
click in plot shift up/dn, left/right to move the plot.
The @ plot is the quick plot. You are correct, it does not autoscale. The X-Y plot that Jean mentioned is a plugin for the PC based software.
I agree, an auto zoom to the correct plot area would be nice
Where is the X_Y plot (axis limits) plugin available for download? Or, if it's already installed, how do you implement it?
I am using windows SMath version 0.99 build 6884.
Thanks!
#22 Publicado: 19/1/2019 14:47:14
1.558 me gusta en 1.868 mensajes.
Grupo: Moderator
You must install it using the extension manager (X-Y Plot Region).
#23 Publicado: 26/1/2019 14:09:03
justhumm
justhumm
OK. I was being stupid...my extension manager was only showing the extensions "local storage". I had to switch it to "online gallery".
Thanks for the reply!
#24 Publicado: 27/1/2019 0:36:46
About X_Y plot: so interesting/useful, so bloody freak in other situations.
If the function includes ln(x) and if it starts from very low,
can't start at 0. Start at very low just crashed Smath [yesterday !]
#25 Publicado: 29/11/2019 11:14:46
miratas
miratas
1 me gusta en 5 mensajes.
yesterday I discovered SMath and I was impressed. I'm Mathcad 15 user, so I like similar behaviour.
But when I started playing with plot I realized that there is no automatic axis setting which is really pain.
I usually use the sheet as "live", so I change some value, do recalculate and instantly see the result in plot. This use is limited here only to small changes which fit in the current plot zoom. If values change more, you can not see them in the plot.
Anyway, thank you for this great tool!
#26 Publicado: 29/11/2019 13:33:43
fedeghi
fedeghi
25 me gusta en 112 mensajes.
Many users plot functions with an additional plugin named "X-Y Plot" (by user "Uni" )
This plugin offers the possibility to control axis limits (and other stuff) using values or variables coming from previous calculation.
I have moved almost every office calculation tool from plotting with Smath native to "XY Plot" mainly for this feature.
You will find this explained in the XY plugin forum section, or more conveniently in remarkable "interactive handbook" prepared by user MKraska.
Just open the handbook and navigate to Graphics->2D Plot (XY plugin)
#27 Publicado: 30/11/2019 10:11:23
Once you will get used with Smath QuickPlot & X_Y Plot,
you will appreciate how superior Smath is vs MCD.
MCD native mesh is ½ pica, Smath is pixel. Thus allows
sizing graphs exactly same width of fine trace vs rough MCD.
1. Size the X_Y plot on your min/max 'x'
2. size Y axis on those min/max ... done.
On rough data points X_Y has spline junction [Isometric example].
For Implicit Trifolium: wait until all frames are calculated,
then see the wind mill rotate ... quick/lovely vs MCD
Solve Implicit Trifolium.sm (29,09 KiB) descargado 1735 vez(es).
X_Y Plot Junior.sm (43,36 KiB) descargado 1739 vez(es).
2D Isometric.sm (92,61 KiB) descargado 1694 vez(es).
Utilities Discrete Algo Range INTERVALS Parts 1234.sm (84,91 KiB) descargado 1732 vez(es).
#28 Publicado: 13/12/2019 7:14:21
miratas
miratas
Thank you both, I need to try it.
I'm now stuck on another thing... I wanted to try to emulate runif and rnorm from MC. And I'm having problems even with runif. See attached.
Thanks,
Mira
runif.sm (1,98 KiB) descargado 1669 vez(es).
#29 Publicado: 13/12/2019 12:01:10
Your attempted code is illegal, simply.
rnorm is another story ... will be back.
runif (1).sm (4,94 KiB) descargado 1734 vez(es).
#30 Publicado: 13/12/2019 12:16:15
Oscar Campo
Oscar Campo
135 me gusta en 309 mensajes.
Grupo: Moderator
Thanks,
Mira
Simply use line() command after function definition as seen on attached image:
Regards!!
#31 Publicado: 13/12/2019 12:28:44
Random_4 Pi.sm (20,56 KiB) descargado 1743 vez(es).
Random_1 Normal.sm (24,34 KiB) descargado 1667 vez(es).
Random_9 Fill Range PDF.sm (31,23 KiB) descargado 1690 vez(es).
Random_6 Weibull.sm (37,44 KiB) descargado 1718 vez(es).
Random_3 Logistic.sm (48,99 KiB) descargado 1740 vez(es).
#32 Publicado: 13/12/2019 18:01:23
miratas
miratas
Thanks for the "line" hint! Is there any explanation why it is needed?
Attached is something which seems to work, also rnorm included.runif.sm (16,17 KiB) descargado 1684 vez(es).
I used histogram implementation found on this forum. It is little bit slow, but otherwise works nicely.
Oscar Campo 16/12/2019 12:24:00
#33 Publicado: 13/12/2019 18:52:20
Is one of very many cases that needs the code be isolated,
particularly this one as it not scalar.
The attached Histogram should work.
Stat Histogram Create Normal Random.sm (70,3 KiB) descargado 1691 vez(es)....SS6179
#34 Publicado: 13/12/2019 19:25:14
Pattern Brownian BER Anim.sm (9,8 KiB) descargado 1619 vez(es).
Higgs.sm (8,25 KiB) descargado 1743 vez(es).
Pattern Brownian.sm (19,74 KiB) descargado 1697 vez(es).
Pattern Brownian Collect Image.sm (24,79 KiB) descargado 1670 vez(es).
#35 Publicado: 16/12/2019 16:07:14
Original version does not work SS 6179.
I made simpler otherwise and accelerated timing by ~ 20.
Will be posted soon included in bigger document "Histogram".
