Improving Calculation Accuracy - Determining the zeros of an equation using "solve" function and using Newton's method - Mensajes
... few more things in this project:
1. roots & Golden ratio in plot.
2. integration/derivative.
Nikolai roots.sm (116,28 KiB) descargado 1280 vez(es).
Hello Jean Giraud,
Thanks again for your attention to my questions.
Could you help me with one more question?
Why can't I calculate in the file "Nikolai roots.sm"?
Clicking the "Recalculate page" button gives the error "F() - function isn't defined.".
Is this a problem in different versions of the program or a problem in another?
WroteWhy can't I calculate in the file "Nikolai roots.sm"?
Total and impressive disaster !
Possibly, your Smath installation is defective ?
Possibly, your Smath version is kaput ?
On that last point, Designers can confirm.
I will make a PDF, so you will be able to code/sanity.
... run that test version. At worst, code as given.
You can'y escape eval(x*Bessel(1,x)-1.01*Bessel(0,x))
Nikolai roots Test.sm (14,75 KiB) descargado 1293 vez(es).
Nikolay 6/9/2022 10:54:00
