MathcadFileAccess
MathcadFileAccess - The following functions are useful for reading various file types into arrays. - Mensajes
#21 Publicado: 27/3/2014 15:30:38
kilele
kilele
134 me gusta en 397 mensajes.
It has occurred to me that the plugin could send the bin data to the clipboard and then the user could make a paste (control-v) by hand into any folder (as the program HTMtied does)
Another alternative could be using DDE as a layer between windows programs, see:
http://jdde.pretty-tools.com/
http://www.thescarms.com/VBasic/ddeml.aspx
ioan92 27/3/2014 16:12:00
#22 Publicado: 27/3/2014 19:42:35
kilele
kilele
have you tried to write to the %TEMP% or %APPDATA% directories ?
ioan92 28/3/2014 4:23:00
#23 Publicado: 28/3/2014 3:25:09
Grupo: Moderator
Perhaps the function GetFolderPath() can help.
ioan92 28/3/2014 3:58:00
#24 Publicado: 28/3/2014 6:00:10
kilele
kilele
Ioan, i'm not sure to understand the problem well
perhaps you can use DAvide's hyperlink plugin
ioan92 28/3/2014 6:22:00
#25 Publicado: 28/3/2014 9:25:05
kilele
kilele
don't ask me why but i think that'll work if you place the sm files at the same directory as smath exe
ioan92 28/3/2014 11:57:00
#26 Publicado: 28/3/2014 12:30:28
kilele
kilele
the two large buttons at the bottom are green in my case, tested with martin's portable version on xp
ioan92 28/3/2014 12:38:00
#27 Publicado: 24/4/2014 18:15:34
1.558 me gusta en 1.868 mensajes.
Grupo: Moderator
Updated. Play() function now works as expected (it waits for the end of sound).
Davide Carpi 24/4/2014 19:22:00
#28 Publicado: 15/9/2015 14:37:12
9_82abZ2
9_82abZ2
0 me gusta en 7 mensajes.
This is as good a place as any:
Is there a function that returns the filename of the current worksheet/Smath Document? I couldn't find it
#29 Publicado: 7/6/2017 4:12:30
Martin_B
Martin_B
22 me gusta en 84 mensajes.
Currently I have the same question and also no answer (and couldn't find one).
Can anybody help?
#30 Publicado: 7/6/2017 15:20:56
Is there a function that returns the filename of the current worksheet/Smath Document?I couldn't find it
Simple but not so simple, EXPLAIN:
1. If your work sheet resides in a subfolder: don't know if possible [didn't find trick]
2. If your work sheet reside in a folder in "C:\ ==> like this
path:=CurrentDirectory("")
path="C:\Smath6179\"
#31 Publicado: 7/6/2017 21:42:05
#32 Publicado: 8/6/2017 3:16:49
Martin_B
Martin_B
Hi Jean,
I do know 'CurrentDirectory( "" )' but it returns the path without the filename. And I am trying to retrieve the latter.
#33 Publicado: 8/6/2017 8:38:18
If I open a work sheet from "My Computer, C, click on the Folder, click on the work sheet
it will open Smath and CWD= is from which folder the work sheet comes from [Snippet].
Differently, If I open Smath first from the task bar, and click on the file name from the
file list on the Smath menu, I get: CWD="C\Program Flies\Smath Studio"
In fact, my Smath is so simple ... all my 925 work sheets are piled in Smath6179 folder.
All in all => same as Mathcad 11
#34 Publicado: 8/6/2017 9:05:42
Grupo: Moderator
Can anybody help?
As workaround you can use simple C# script for this (Script plugin).
store.AddDefinition( terms[0].Text, new Term[0], new Entry( "\"" + store.FileName + "\"" ) );
#35 Publicado: 8/6/2017 11:46:34
A more complete code would look like Mathcad 11
CWD="C:\Program Files\Mathsoft\Mathcad 11\Handbooks\datapack"
#36 Publicado: 29/10/2019 5:05:48
Grupo: Moderator
The function getfolderpath() seems to be broken for build 7219:
getfolder.sm (2,21 KiB) descargado 1778 vez(es).
Mostrar spoiler
#37 Publicado: 31/10/2019 14:05:49
Grupo: Moderator
Updated and rebuilded for SMath Studio ≥ 0.99.7109.
Martin Kraska 31/10/2019 20:00:00, sergio 2/11/2019 14:46:00
#38 Publicado: 29/6/2021 8:08:28
Oscar Campo
Oscar Campo
135 me gusta en 309 mensajes.
Grupo: Moderator
I found that the following functions of this plugin are not working:
Play(), WRITEWAV(), GETWAVINFO(), READWAV().
I saw the problem inside the interactive SMath Handbook.
I have SMath Studio 0.99.7822 (01 June 2021) on win10.
Oscar
#39 Publicado: 29/6/2021 9:47:38
Grupo: Moderator
SMath Studio compatibility
Plugin updated. Please try.
Changes:
- plug-in corrected to respect latest SMath Studio API changes.
Oscar Campo 29/6/2021 10:15:00, sergio 29/6/2021 11:55:00
