GNU Scientific Library (GSL)
GNU Scientific Library (GSL) - The GNU Scientific Library 2.x. - Mensajes
#21 Publicado: 20/12/2021 16:11:14
1.558 me gusta en 1.868 mensajes.
Grupo: Moderator
SMath Studio compatibility
Plugin updated.
Changes:
- solution restructured;
- converting the task for the ODE solver to the numerical form is now performed through the Mathcad Toolbox plugin (to avoid code duplication), so it must be installed;
- refactored.
Solvers that support mathematical notation now reuse code from the Mathcad Toolbox plugin. Now there is no need to recompile every such plugin.
#22 Publicado: 24/12/2021 6:00:02
Grupo: Moderator
Updated.
Changes:
- updated to GSL 2.7;
- gsl_version operand added;
- refactored.
#23 Publicado: 24/12/2021 11:13:05
Grupo: Moderator
Updated.
Changes:
- gsl_sf() function added (only airy supported);
- totally refactored.
The library has a huge number of functions, but it is very difficult to find a convenient method for calling them. I decided to try one method, calling special functions with one generic function and a combination of flags.
Click to enlarge
sergio 24/12/2021 12:20:00
#24 Publicado: 24/12/2021 18:28:46
Grupo: Moderator
SMath Studio compatibility Examples
Updated.
Changes:
- gsl_sf_airy() and gsl_sf_bessel() functions added;
- gsl_sf() function removed;
- examples added;
- refactored.
Click to enlarge Click to enlarge
Links:
1. Airy Functions and Derivatives
2. Bessel Functions
#25 Publicado: 1/2/2022 9:27:54
DenisArd
DenisArd
0 me gusta en 1 mensajes.
Плагин установлен и виден в SMath, но ни одна его функция не доступна. В чем может быть дело?
The plugin is installed and visible in SMath, but none of its functions are available. What can be wrong?
Windows 10 Home x64 21H1, SMathStudioDesktop portable (mono).
Upd: Разобрался. Нужен Microsoft Visual C++ 2015 Redistributable.
Understood. Requires Microsoft Visual C++ 2015 Redistributable.
https://www.microsoft.com/ru-ru/download/details.aspx?id=53840
#26 Publicado: 3/6/2022 15:51:43
Grupo: Moderator
SMath Studio compatibility gsl_interp.cpp
Updated.
Changes:
- gsl_interp() function added.
Click to enlarge
gsl_interp.sm (8,07 KiB) descargado 1908 vez(es).
Links:
1. GSL Interpolation.
churichuro 3/6/2022 19:00:00
#27 Publicado: 5/6/2022 13:32:31
Grupo: Moderator
Resources
I finally figured out how to add a localization mechanism for function libraries. In the future, I will use it in all my plugins.
sergio 6/6/2022 6:46:00
#28 Publicado: 10/3/2023 10:27:36
Grupo: Moderator
Updated.
Changes:
- gsl_sf_erf(1), gsl_sf_erfc(1), gsl_sf_erf_Q(1), gsl_sf_erf_Z(1), gsl_sf_hazard(1) and gsl_sf_log_erfc(1) functions added.
sergio 10/3/2023 17:10:00, Oscar Campo 14/3/2023 6:35:00
#29 Publicado: 3/3/2024 14:18:11
Hi Viacheslav. It looks like a bug.
#30 Publicado: 4/3/2024 14:24:55
Grupo: Moderator
As for the last error, this is by design. Function expected as first argument.
Click to enlarge
Here my results:
Click to enlarge
The problem may be related to this
Click to enlarge
I don't know exactly which one is used by the plugin. You can try reinstalling the Microsoft Runtime support library.
#31 Publicado: 4/3/2024 17:04:27
Grupo: Moderator
Updated.
Changes:
- gsl_msc_ver and gsl_msc_full_ver operands added.
Maybe this will help in the future.
Click to enlarge
Mostrar spoiler
Links:
1. Microsoft Visual C++ compiler versioning
2. How to Detect if I'm Compiling Code with a particular Visual Studio version?
I do not attach the necessary package with support libraries because I don't know what compiler the project itself is built with. This is done on the build server side and may change from time to time.
All similar plugins have a similar problem.
sergio 5/3/2024 2:59:00
#32 Publicado: 4/3/2024 22:19:45
Hi Viacheslav. Thanks. I forgot to tell the operating system: Win10 32 bit. I check the 64 bit version and works fine, as you says. The library gsl32.dll seems to need vcruntime140.dll and msvcp140.dll. I see if I can update Microsoft Runtime support library also.
#33 Publicado: 5/3/2024 0:54:12
Grupo: Moderator
There really is a problem with the 32-bit version of the GSL. I can't debug the function because it gives me an error. This may be due to the project settings for building the 32-bit version of the plugin.
P.S. Only some of the functions in the 32-bit version of the library do not work.
Alvaro 5/3/2024 12:49:00
#34 Publicado: 8/10/2024 22:38:03
Lupus the Canine
Lupus the Canine
0 me gusta en 7 mensajes.
Would it be possible to correctly handle units in formulas. Right now, units are present in the first step but then stripped away breaking formulas.
#35 Publicado: 8/10/2024 22:51:35
Grupo: Moderator
I'll think about it. There are about 30 types of solvers supported now and I'll need to rework them all. If I can rework a few solvers, I'll use that experience to update the rest. But I can't promise anything yet.
