Writer Region Plugin - Provides the ability to work with formatted text inside the Worksheet. - Mensajes
Strictly about WriterRegion plugin, I can't test it now but only the recent beta versions with direct math editing should be affected (latest stable has still the plain text dialog and should be safe)
- [MONO] color pickers dropdown menus are now available in mono;
- [MONO] special characters dropdown menu is now available in mono;
- now it is possible to choose a set of favorite colors to have in your color pickers (right click to choose/change the color, SHIFT+right-click to clear it);
- "more colors" dialog now popups always on top of the settings toolbar;
- fixed history steps issues wrt toolbar actions;
- fixed hyperlinks not detected before clicking into the region;
- SMath Studio interfaces usage updated;
- refactoring;
please note: You might experience some blurriness here as well as in regions of other plugins, it will be fixed in next plugins updates (it affects rendering on displays only, printing is not affected).
- restored Math plain input dialog (I will try later to handle the localization issues related to direct edit);
- several aliasing blurriness fixes;
- fixed exceptions while wrapping empty indented paragraphs;
- fixed font color not retrieved from default settings;
- new feature: Lists (see below);
- all meaningful keyboard shortcuts are now summarized in the "commands list" dialog (available from toolbar or using F1 key; filters are available to find easily what you are looking for);
- context menu options extended (paragraph's style, character's style, paste special...);
- restored the double-click word selection;
- restored direct input in math items (fixed localization issue spotted in previous releases);
- direct math input now supports F8 renaming and CTRL+K special characters mode;
- improved mouse events when the region gain the focus and a worksheet scroll is triggered;
- improved plain text serialization;
- fixed greed history steps on Wrap;
- minor fixes;
- refactoring;
Lists: Unordered, Ordered, on single or multiple levels. Several enumeration types provided (more can be added upon request).
Archivo no encontrado. Archivo no encontrado.
To customize the marker style (font size, colors, decorations...) select the markers (mouse click or CTRL+ALT+L) and change the style as usual; marker type and specific properties can be customized from dialog via toolbar/context menu/keyboard shortcuts;
P.S. (1) files that contains lists won't load if you don't have this plugin version; if everything works fine I plan to provide some releases for older versions of SMath Studio;
P.S. (2) TextRegionUtilities plugin will be updated later these days;
I have detected the following problems
1) Opening existing files: each writer region is not shown
2) Creating new file: the new writer regions are correctly created and displayed, but after closing and reopening the file, they are not visible
Wroteafter updating to SMath Studio 0.99.6953
I'm working to fix it. New SMath Studio nightly build will be available later today.
I don't know if this happens only to me but I can't seem to find the "ok" and "cancel" button on the custom bullet list.
Can you help me on this? Thanks!
Nathan
Archivo no encontrado.Archivo no encontrado.
WroteI don't know if this happens only to me but I can't seem to find the "ok" and "cancel" button on the custom bullet list.
Confirmed, thank you.
WroteCan you help me on this? Thanks!
Plugin updated. Download it to get the fix.
- fixed scaling on high DPI devices;
- fixed subscript/superscript on context menu;
- refactoring;
- [mono] fixed regions disappearing on worksheet scrolling (previous update);
WrotePlugin updated. Download it to get the fix.
Thank you sir!
Just a suggestion: I think underlining of text should be reviewed in order to draw this line under the text using DrawLine. This approach will allow to change color and style of the underline and this will fix issues like these: when justify allignment set for Paragraph.
(Word vs Writer Region)
One note: Word do not even render space at the end of a line. Otherwise we may expect glitches like this:
I'm working to fix issues like this one in Text Region, so this may be interesting to you as well. Seems Underline Style of the Font is something not good for those who renders text themselves.
WroteHello Davide!
Text-decorations are already owner drawn, this it's really weird, I have to investigate why it looks so bad
edit: I haven't noticed that in your screenshot there was a justified text, missing lines fixed, thank you!
WroteOne note: Word do not even render space at the end of a line. Otherwise we may expect glitches like this
Yeah I know, something to improve, has bad impact on justified alignment as well
- fixed wrap shrink while switching wrap property from none to custom;
- fixed text-decorations of whitespaces on justified text;
- fixed caret not hidden on selection;
- minor fixes;
- refactoring;
[beta feature] starting from this version (0.21) a rotation in clockwise degrees can be set for the whole region content (as for now you can enable it only by editing the worksheet code)
<writer rotation="30">...
- trailing whitespaces are no more counted in the alignments (like in regular rich text editors); when focused, if some whitespaces fall out of the region width, a greyed area is now shown on the right side to let you navigate them - even, properties are kept but not shown if they are there.
- new "rotation" context menu (as for now only with 90 degrees rotations);
- minor fixes;
- refactoring;
Question about fields insertion. I cannot find some fields,
which are available in SMath. For example:
- "Worksheet revision"
- "File name"
- "Current page index"
With the Menu of SMath "Insert -> Fields" the fields are only
updated in standard TextRegions, but not inside WriterRegions.
With the Menu of WriterRegion "Insert -> Fields", of course the fields
are updated, but only 7 out of 13 fields are available.
Kind Regards
Mathys
![2019-06-25 16_40_44-SMath Studio - [rot.sm_].png](/es-ES/files/Download/7hZFUu/2019-06-25-16_40_44-SMath-Studio---[rot.sm_].png)
