Clipboard Region
Clipboard Region - Messages
#21 Posted: 12/8/2025 12:59:40 PM
zhkz
zhkz
3 likes in 14 posts.
PLEASE REPORT HERE ANY ISSUE
hi Davide
glad to find this extension ,but it seems dont work when export value
for export variable value , click Right-pointing triangle then it comes to an error , nothing copied to clipboard
for import value to variable , click left-pointing triangle then it works as expect
I'm not sure if the problem is on my end or with the plugin.
#22 Posted: 12/9/2025 6:13:52 PM
1,440 likes in 2,928 posts.
Hello, I'll check it, at first glance seems an error plugin-side.
#23 Posted: 4/11/2026 6:49:46 AM
Norrah_Casper
Norrah_Casper
0 likes in 6 posts.
This is honestly such a lifesaver for moving data between SMath and Excel. Even with the occasional formatting quirks with negative values or scientific notation, it’s much faster than manual entry. I've found that using a quick 'str2num' or 'strrep' usually clears up those string issues in a pinch.
#24 Posted: 4/27/2026 11:27:38 AM
hi Davide
Found the issue, fixed code uploaded in the SVN. Can't release the plugin because (I think) there is an issue server side on the relase manager.
Quote
warning MSB4243: The NuGet-based SDK resolver failed to run because NuGet assemblies could not be located. Check your installation of MSBuild or set the environment variable "MSBUILD_NUGET_PATH" to the folder that contains the required NuGet assemblies
possible solution (for Andrey/the devs): https://stackoverflow.com/questions/79259398/the-nuget-based-sdk-resolver-failed-to-run-because-nuget-assemblies-could-not-be
Edited 4/27/2026 11:36:11 AM
sergio 4/27/2026 3:44:40 PM
#25 Posted: 4/28/2026 1:53:52 PM
SMath Israel
SMath Israel
2 likes in 2,364 posts.
Group: Administrator
Dear David,
The finding was caused by new project format. Andrey performed necessary adjustments. You may finish your work now.
Gleb
Davide Carpi 4/28/2026 1:58:05 PM
#26 Posted: 4/28/2026 1:59:58 PM
Thank you very much!
Plugin updated
Andrey Ivashov 4/28/2026 3:37:50 PM
