Check Valve
Check Valve - Programing help - Messages
#21 Posted: 5/25/2016 2:20:17 PM
Ruben Sidranski
Ruben Sidranski
17 likes in 465 posts.
20 yrs experience ... more than 1/2 in the field. Which is why I love these conversations.
If anyone is interested, there is a check valve webinar @ 2 pm EST. ... in 45 minutes for me
http://www.globalspec.com/events/eventDetails?eventId=1112&gotoEventNotReady=1
I've never used a plug valve for control on purpose. Need to look at valve authority and other parameters. However, many "balancing valves are "ball" valves which, to me, are rejected, but I have seen them used. As a general rule, I equate ball and plug together ... just better more robust seating on the plug
#22 Posted: 5/25/2016 6:18:55 PM
"Don't look at valve authority and other parameters".
Rather, look at various process plants and their authoritave "know how" from nearly a century.
They work well and ~ 70 years automated from primitive to very sophisticated.
Finally, I don't understand what you are looking for ?
Maybe, valve manufacturers is a better place than Smath forum about your unclear "Crane check valve".
I will end it there unless if you have real project question(s).
#23 Posted: 5/31/2016 4:18:46 PM
Ruben Sidranski
Ruben Sidranski
So, the corrected calculation results in different selection: 18 in instead of 16.
Mike, Thank you for catching an error ... ID. On the smaller pipe diameters, of which this was based off of, that was not as big as a deal as the ID is actually bigger than the pipe size.
Thank you Carlos and Jean for the inspiration on the programing loop
BTW, This calculation WAS specific for a swing check valve which is common for AWWA (90 degree swing, non-UL listed). If you look at the Crane manual, different velocities are recommended for different styles of check valves. I added a tilting disc as an example too. A good U.S. rule of thumb is 7 to 10 feet per second for a check valves even per manufacturers.
Attached is the final version which is based on Crane TP410. Someone made a point about "Not enough Collabs post working files" Check Valve Sizing.sm (34.57 KiB) downloaded 876 time(s)..
